Old 12-19-2011, 06:05 PM   #5341 (permalink)
Thanks for all the answers... I could build a mechanical throttle stop, but I'd prefer the software method I'm slowly building an electric T-Bucket that will weigh about 1000 pounds. I have a 7.2" Prestolite motor that I'm told that I should try to keep at 80v max. That's fine because I only need a 45 mph speed, but I'd like to to run a higher voltage to keep the battery amps lower.
Old 12-20-2011, 04:08 AM   #5342 (permalink)
EV Connoisseur
Wouldn't it be more efficient to advance the motor and use all the volts available?
Old 12-20-2011, 04:22 AM   #5343 (permalink)
usually the motor can't handle the RPM's cause by high apparent voltage
Old 12-20-2011, 11:53 PM   #5344 (permalink)
PaulH
MPaulHolmes's Avatar
First I forgot to mention! My wife just gave birth on Saturday. We left the house at around 3:40am, and got checked in to the hospital at 3:50, and she delivered at 4:30am. It was disturbingly close. haha.
I did a test of the new controller with the Bike permanent magnet motor at 24 volts and it has a voltage turnoff spike of about 1 volt overshoot per 17.5 amps. This is significantly less overshoot than the 500amp version. In the 500amp version, I believe Joe got a 25v spike at 180 amps. 1 volt of overshoot per 7.2 amps.
Joes test:
Video of my test coming soon...
kits and boards
The Following 3 Users Say Thank You to MPaulHolmes For This Useful Post:
bjdEV (12-21-2011), deodeo (04-22-2012), mpgmike (01-21-2022)
Old 12-21-2011, 01:54 AM   #5345 (permalink)
Congrats on the new kid!
The Following User Says Thank You to madmike8 For This Useful Post:
deodeo (04-22-2012)
Old 12-21-2011, 08:52 AM   #5346 (permalink)
congrats on the new addition to your family
Old 12-21-2011, 09:12 AM   #5347 (permalink)
ReVolt Enthusiast
Congratulations Paul !!!
-Mark
Old 12-21-2011, 02:17 PM   #5348 (permalink)
dave koller's Avatar
First I forgot to mention! My wife just gave birth on Saturday. ..
(PS - they know what causes that now..... )
Dave ...
Old 12-21-2011, 07:48 PM   #5349 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Again, congratullations in the new addition to the family, GOD bless them all.
Prius Absolutum Dominium . ..........KOPPER
PHEV conversion since Dec 2006.. . .... .Future EV
. . . . . . . .CALCars # 27. . . . . . . . . . ..on the works now !!
Old 12-23-2011, 02:31 AM   #5350 (permalink)
PaulH
Turn off is perfect, but turn ON has a bit of ringing, so I tried one driver per mosfet, and that was no help, so I reduced the gate resistor value to 5 Ohms, and that didn't help either. I don't know why that would help, but whatever. haha. So, I ordered some mica capacitors whose job is to smooth out very high frequencies. The ringing is at 25 MHz. We'll see what happens. But overall, every concern I had has been dealt with. I think it's actually going to work. Hurray! And it's easier to assemble.
EDIT: I actually just didn't know how to use my stupid oscilloscope. The lower gate resistors basically eliminated the ringing. Hurray! This is actually going to work! I don't THINK it's going to work! hahaha. Ben, as soon as I get it all spick and span, just you try and blow this sucker up. Hmm... is the other controller having any cold temperature issues?
I took it apart and reassembled the control board adn driver board like 4 times now to test different things to eliminate the ringing, so I might need a new driver board, but maybe not. There are a few little details that could change, but nothing major! I guess 5th times the charm.
kits and boards
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
