Old 02-11-2018, 09:05 AM   #7211 (permalink)
Well, I'm getting no response over serial no matter what software I load on the chip, what terminal application I use, what cable I use, or what computer I use. It doesn't respond to throttle and never switches the IGBTs. The board is very different from the rest of these - I've attached some pictures. I think I'm stuck waiting for Paul to send the software.
Name:	Control Board.jpg
ID:	23480  Click image for larger version
Name:	Control Board 2.jpg
Old 02-11-2018, 03:01 PM   #7212 (permalink)
ChargE - '92 Mazda MX6 LX
90 day: 33.89 mpg (US)
WinterTransport - '07 hyundai Sante Fe SE
It powers up with a message after the serial is initialized .. I think the firmware version waits for maybe the throttle signal to be in range?
It was an annoying thing that I had to have the throttle connected before I could see anything.
Is it set up for a hall effect throttle or a potentiometer?
Another item - TX is transmit from the board, RX is receive to the board. A USB-to-serial adapter usually has this already switched. But if you are using an old-school serial port you need to switch pins 2 and 3. Pin 5 is ground on a 9 pin connector. With a scope on the TX and GND pins you should see *SOMETHING* if it is transmitting. I think it's 0V low and 5V high ... not -12V low and 12V high as the original RS-232C specifies.
Another thing that Paul sometimes (usually) forgets is to re-compile without debug mode. So the chip could be sitting there - waiting for a 'go' from the PICkit 3. If you load the hex file I sent that would not be the problem ... but that board looks different from mine. Surface mount dsPIC, driver chip for the serial. If you manage to compile the code I sent, you can change the code and put out a test signal of some sort. But I'm not sure if you are wanting to mess with that stuff.
Let us know if we can help
In THEORY there is no difference between Theory and Practice
In PRACTICE there IS!
The Following User Says Thank You to thingstodo For This Useful Post:
Piotrsko (02-16-2018)
Old 02-14-2018, 04:22 PM   #7213 (permalink)
So, I reversed the TX and RX lines and got some garbage outputs like I did before. I should have mentioned it that earlier. I made a wrong assumption that I was getting garbage because it was crossed.
Paul sent me the software for the new board just now (woohoo!). I have the throttle hooked up properly and the serial connections set up. When I get home tonight, I'll give it a whirl with the correct software.
Old 02-15-2018, 12:33 AM   #7214 (permalink)
PaulH
MPaulHolmes's Avatar
Yes this is 99% the old DC code, so it still requires a throttle connected that is moved into valid territory before starting things like the serial communications. What I ought to do is port over the AC code into DC code, so that all the serial communications matches for both of them. That would probably take a week to do and then debug it.
kits and boards
Old 02-15-2018, 10:57 AM   #7215 (permalink)
OK. I'd rather see garbage than nothing since sometimes I just have the baud rate wrong
Can you (or Paul) send me a copy?
Paul is not known for judicious backups (!!)
Old 02-15-2018, 12:41 PM   #7216 (permalink)
Link in next post since I'm at 4 posts... lol.
Old 02-15-2018, 12:42 PM   #7217 (permalink)
High Power DC Board Software
The Following User Says Thank You to jbman For This Useful Post:
thingstodo (02-15-2018)
Old 02-15-2018, 12:47 PM   #7218 (permalink)
I must be too fast - just see hex file so far. I'll wait a few minutes!
Old 02-15-2018, 01:16 PM   #7219 (permalink)
Ah, I'm afraid I only have the controller and debug hexes at the moment. Paul will have to provide the source. I've put both hexes in that share, though.
Old 02-15-2018, 02:12 PM   #7220 (permalink)
Yup - got'em
Paul - any chance of a 'backup email' in the near future?
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3256 Today 06:22 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
