Old 01-25-2012, 09:58 PM   #41 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
But probably it goes in the regular garbage.
I empty mine at oil change intervals, so the gunk gets dumped into the oil change drain pan -> taken to auto parts store when new oil/filter is bought (recycled) -> return to step one.
I change oil on 5-6 cars in the family, so throwing it in the trash wouldn't be feasible, let alone responsible.
So, I'm trying to understand how this sealed system that returns gasses directly to the intake is venting HCs:
(apologies for posting the same picture twice, but "Refer to Figure A" doesn't seem popular)...
Is there a disconnect between a commercially bought "Catch Can", and a DIY system, as pictured (and what Josh8loop has prepared)?
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 01-25-2012, 10:47 PM   #42 (permalink)
Definately a Modder!
Your right, in that sealed system any vapors that travel through the filter get the opportunity to be burned in the engine. Like mentioned fluid can be drained and recycled or disposed of in some other responsible manner. Mine is also sealed like the above setup, except I empty the liquid oil into my crankcase after it is filtered through Terry cloth.
2002 VW Jetta TDI 5-speed(completed 01M-5-speed swap at 155K miles) 45 MPG City with the 01M, 5-speed 58+ MPG City. Experimenting with the "Hybrid" 205 Deg F T-stat:
http://forums.tdiclub.com/showthread...=306799&page=4
Old 01-26-2012, 06:30 PM   #43 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
I don't put anything from the catch can back into the engine, I just recycle it. It's not just oil, but a mixture of whatever crap shows up in the crankcase, unburned fuel, cylinder blow by, water vapor etc. It's mostly oil but I wouldn't try to lubricate an engine with it.
More choices...
Old 01-26-2012, 06:51 PM   #44 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
chain saw oil
Old 01-30-2012, 11:02 AM   #45 (permalink)
I'm not too worried. I run higher than normal temps in my TDI(205-209 F) so the water will be vaporized and flow through the CCV into the intake. Also, from what I can see the oil collected is very clean, and I strain it to make sure. remember were only talking about a little over 1 ounce per 10K miles.
Old 01-30-2012, 03:24 PM   #46 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
basically, a pointless exercise.
Old 01-30-2012, 04:01 PM   #47 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
A lot of cars that have an oil separator do drain it back into the oil pan. Any unburned fuel and water get boiled off when your engine is at its proper operating temp. So dumping it back into the crankcase does no harm.
Old 04-25-2012, 02:12 PM   #48 (permalink)
Not pointless in my case-it keeps oil from accumulating in my lower intercooler which if it accumulates too much can be sucked into the engine causing runaway or hydrolock. I love my setup, it lets me know the general health of the engine/turbo combo, and never leaves me guessing if my lower intercooler has oil accumulation!
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
PCV Catch Can on Metro? SirKeats DIY / How-to 14 09-27-2009 04:31 PM
DIY: Make a PVC Catch Can for your PCV System TomO DIY / How-to 0 11-14-2007 03:30 PM
