Old 07-13-2008, 12:31 PM   #11 (permalink)
Try This SirKeats
What I did was pipe everything over to the right side of the engine compartment and put my PCV catch can there. I used a 2 1/2" pvc pipe with rubber plumbing caps on the top and bottom. Put the inlet line down to the bottom of the pipe and the outlet near the top.
I used silica alumina and zeolites (both catalysts) inside the unit. The zeolites act as a molecular sieve and break down the hydrocarbons from long chain into short chain. That's what the professionals (oil refineries) use to achieve a 41% increase of petroleum cracked into the gasoline range from the same amount of crude oil.
You need to pipe out of the valve cover outlet to the can and down to the bottom of the pvc pipe as mentioned. Then out of the pipe near the top and then you will have to put a tee into the line to go to the air breather and into the regular PCV valve.
HTH,
MooNShiNeR
Old 09-25-2008, 11:54 PM   #12 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
A catch can serves the same purpose as a breather. It really is not needed unless you have a blow by issue.
Old 09-22-2009, 10:34 PM   #13 (permalink)
Ryanrpm's Avatar
Ryanrpm's Tundra - '05 Tundra Limited, Double Cab, 4x4
90 day: 17.59 mpg (US)
1993 Civic EX 1.6L - '93 Civic EX
90 day: 49.61 mpg (US)
I'm almost done with my little PCV bubbler/catch can. Mine will be able to draw in water vapor along with any other PCV gasses. I'll fill it halfway with water, and let it do its work.
It serves to condense all the crud as well........and.........it works in the winter time too. When the water freezes, the gasses will still be able to come through those holes on the upper half, and the ice will help condense the heavy oils. Then, in short order, the ice will melt from being hit with the warm gasses and the engine heat.
1993 Honda Civic EX - Latest Hwy mileage: 45 mpg.
Current mods: Ozone extraction from Distributor cap. O2 sensor wrap. Mudflap reversal. Wiper delete. Side mirrors delete. A/C delete.
Old 09-27-2009, 04:15 PM   #14 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
catch can. its hypocrisy. its like 4 valves a cylinder. its like fuel injection.
if its a vapor, let it in the combustion chamber, if its
something your trying to catcj, extend current pcv lines with a aluminum, near the warm engine. no catch can needed...you got an oil pan. a catch can is like saying.. I got a model t with no oil filter nor pump, things just splash around.
The Following User Says Thank You to bgd73 For This Useful Post:
Frank Lee (09-27-2009)
Old 09-27-2009, 05:31 PM   #15 (permalink)
Ryanrpm's Avatar
Hmmm. I'd like to say "Thank you" also for your post, but I'm not following you. Can you repeat it simpler terms that newbies like me can understand?
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 10:38 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 11:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 08:26 PM
DIY: Make a PVC Catch Can for your PCV System TomO DIY / How-to 0 11-14-2007 04:30 PM
