Old 05-29-2008, 12:29 PM   #1 (permalink)
SirKeats's Avatar
GeRide - '89 Metro *XFi
90 day: 54.26 mpg (US)
PCV Catch Can on Metro?
Anyone ever rig up a PCV Catch Can on their Metro?
Have any pics? I started to play around with setting one up last night but had trouble getting it to fit. Just not enough space to run the tubes. Would love to see if anyone else has had better luck.
I'd assume that a catch can would aid in efficiency since it's removing pollutants from the fuel stream.
Thanks!
Old 05-30-2008, 06:47 PM   #2 (permalink)
SirKeats's Avatar
no one???
Old 05-31-2008, 10:24 PM   #3 (permalink)
Blue - '-1823 P/U
do you have that much blow-by ???
Old 05-31-2008, 11:47 PM   #4 (permalink)
SirKeats's Avatar
not that i'm aware of... i just not this to be a fairly common performance mod (for speed daemon folks) that i assumed would also transfer over to ecomodding well as it removes pollutants from combustion which should, i would think, increase efficiency.
Old 06-01-2008, 12:31 AM   #5 (permalink)
Blue - '-1823 P/U
your stock system should be fine if its working correctly
Old 06-01-2008, 09:24 AM   #6 (permalink)
SirKeats's Avatar
lol... yes. i realize it should be fine. as should all the other stuff we change on our cars before we change it assuming it's working properly before we change it.
we're all here though because we enjoy tweaking our cars for max efficiency. thus the question.
Old 06-05-2008, 07:22 PM   #7 (permalink)
I did it for a mazda mx6 once, not a metro...
it helps the "speed demons" accelerate faster by decreasing the chance of having the O2 sensors tripped leading to a strangled fuel injection
I'd save a little time and busy work and just skip it, but that's just me
Old 06-10-2008, 03:32 PM   #8 (permalink)
Red Egg - '95 Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
Extra oil in the combustion chamber lowers the effective octane of your fuel. So for example if you are trying to bump your timing to the ragged edge for mileage and power gains and are pinging, removing the blowby oil may help before you back the timing down or choose the next higher grade of fuel. Out in California the best gas we get is 91 octane so I put a catch can on my turbo'ed car.
Old 06-10-2008, 08:00 PM   #9 (permalink)
SirKeats's Avatar
ya... i'm having a hell of a time figuring out how to best route the hoses and such. things are just so tight down there. wish someone else had done this before on a metro so i could just copy their setup. LOL. guess i'll just have to go it alone!! hehehe
Old 06-29-2008, 10:35 PM   #10 (permalink)
Power tuner gone eco
whatthe's Avatar
Prudence - '93 325 i
90 day: 36.64 mpg (US)
Just slap the catch can inline and use it as an oil separator.
Don't vent PCV to atmosphere as it will longer pull a vacuum. The purpose is to increase pressure differential accross rings and help rings seal, reduce blow by, etc.. Autozone/Partsource or what have you sold those crappy PCV filters and everybody used them... they would have decreased performance compared to factory or a proper system.
1992 - Suzuki Swift GT
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 10:38 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Planning Project Eco-Z seanof30306 EcoModding Central 20 08-24-2009 11:00 PM
Metro Hoarding 101 - also: Metro pickup trucks! Cowspots Introductions 28 04-14-2008 08:26 PM
DIY: Make a PVC Catch Can for your PCV System TomO DIY / How-to 0 11-14-2007 04:30 PM
