Old 09-14-2010, 10:06 AM   #1 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Villager gs
90 day: 19.8 mpg (US)
Max - '98 Maxima SE
90 day: 26.89 mpg (US)
Percentage increase in MPGs for simple mods?
I recently added partial grille block to my minvan, and in a half tanks worth of driving saw the difference on the tripometer. So I did the same thing to the Max and noticed the difference on the scanguage.
While I realize a grille block will have varying results according to average speed and size of grille opening etc, it struck me that I increased the mpg possible from my van about 10% with a bit of old vinyl siding and some zip ties. Are my results just not completely tested, or is a grille block (or other smaller mods) much more effective than I am led to believe?
Gotta love wife, kids, and car!
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 09-14-2010, 11:03 AM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
take a look at the wiki for some real life mod data:
Car MPG Efficiency Modifications Main - EcoModder
your numbers sound a bit high, but not past the range of mod + normal driving variation.
Old 09-14-2010, 04:56 PM   #3 (permalink)
The Putter - '00 Golf
What was your test speed?
Old 09-17-2010, 12:12 PM   #4 (permalink)
Basjoos Wannabe
Max - '98 Maxima SE
nearly everywhere I drive has a speed limit of 40 or higher, and there is a stretch of about 5 miles to town over 50, so I'd say aero mods would make a big difference. I'd chock this discussion to more info needed for a couple weeks til I can get a tankful of miles behind me. Tends to take a while with a 20 gallon tank though.
Old 10-02-2010, 04:06 PM   #5 (permalink)
6% tops!
The SAE credits the cooling system at about 12% of overall aerodynamic drag.
Completely eliminating the cooling system would provide a 6% mpg improvement at 55-mph,a little more at higher speed.
Accordingly,10% would be a little high,although on a case-specific basis it is possible.
Old 10-03-2010, 04:25 AM   #6 (permalink)
Basjoos Wannabe
Max - '98 Maxima SE
I wonder what the aero drag percentage of a minivan is.... I suspect a bit lower, due to larger frontal area.
Old 10-03-2010, 09:56 AM   #7 (permalink)
Wiki Writer
bugler - '91 626
90 day: 35.89 mpg (US)
yea 10% is a bit high i think, if you look at your frontal area of your car and look at what percentage of frontal area your grill block is its probably less than 10%.
You might however be getting an advantage from higher engine bay temperatures, quicker engine heat up times.
Id still be surprised with 10% but would be great if you are getting that much improvement.
regarding the fact that its a simple mod, whenever i do another mod to my car i am continually surprised by how easy they all are (so far), makes me think i should have done this a long time ago.
Newb - better MPGs out of a Dodge Neon? stevewww EcoModding Central 7 10-21-2011 08:50 AM
Pulse&Glide, and aero mods, big mpg increase. Sulfuric Success Stories 3 01-15-2009 11:57 AM
[article] 5 Real DIY Aerodynamic Mods Detroit Can Add for MPGs in '09 SVOboy Aerodynamics 15 07-01-2008 01:57 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 07:46 AM
