Old 07-01-2008, 11:54 PM   #1 (permalink)
Here, there, everywhere
regor's Avatar
regor's civic - '08 civic lx
90 day: 39.95 mpg (US)
performance chips. Do they really increase MPG?
I've seen these ads regarding performance chips. Herer's one that staes a MPG increase-
SLR Motorsports
I'm curious if they really do increase MPG and if so, how hard are they to install?
Thanks
I drive-
08 Honda Civic LX sedan, auto
01 Chevy Silverado truck
99 Ford Contour sedan (Well, that's the wife's).
And a 1907 Baldwin Steam Locomotive (Really)
I tend to convert to Mobil-1 around the 8K mark
I'm also a believer in "Tufoil"-been adding that in my vehicles for 20+ years (And yes, I'm experimented with Duralube, Slick50, Prolong and zmax, and what did I find? No improvement in MPG. I keep on coming back to Tufoil).
Old 07-02-2008, 01:09 AM   #2 (permalink)
They do on the diesels, I dont have one on a gas engine to tell you about that. My guess is yes but you might need higher octane to do it.
Old 07-02-2008, 04:14 AM   #3 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 42.23 mpg (US)
regor -
This is ... fascinating (say it like Spock). I never heard of a chip for a Saturn (everything is soldered to the ECU/PCM). ... wait a minute ... Google google google :
SLR motorsports chip
Check the "chip" and see what plug it has. Most likly you need to plug it into the harness and cover the sensor''s connector. If not then you got ripped off. Most of those so called "chips" are nothing but a resitor that gives the computer a predetermined value. It most likely will not do you any good installing that "chip". I would return it and try to get your money back.
If you are trying to get more power from your engine then have the PCM retuned (reprogrammed) it is the ONLY WAY to get what you want from the PCM.
It's an IAT resistor-mod chip. It would only boost horsepower (more fuel injected) under WOT/open loop conditions. Nothing to do with MPG. The pictures on the site are misleading because they imply that it is a real computer chip.
CarloSW2
American Solar Energy Society
Old 07-02-2008, 04:08 PM   #4 (permalink)
IF the chip increased (advanced) spark timing, and IF the fuel you used (or added water/ethanol injection) could handle it without pinging, then a different calibration could improve fuel efficiency. Some cars have knock sensors and will automatically add spark if you're using higher octane fuel (the EPA tests are all run with 98 RON gas -- very good premium).
Personally, unless I knew exactly what these chips did I'd stay away from them. Too great a chance they could damage the engine.
FP Plus for Gasoline. Does it increase MPG? regor EcoModding Central 1 06-30-2008 01:52 AM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 05:58 PM
New here, want to know how to increase my MPG. MartialArtist EcoModding Central 12 03-26-2008 03:14 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 10:15 PM
Here From TDIClub - looking to increase highway mpg dremd Introductions 27 02-25-2008 09:36 AM
