08-13-2008, 10:10 AM
#11 (permalink)
I found a shop where they sell rubber strips from 2inch. I will use one of those to make an airdam. Rubber is flexible so when i hit somethink it wil bend.  Maybe is that also an idea for your car.
NOW INTERACTIVE! Joystick controls Fry's left ear.
08-13-2008, 01:01 PM
#12 (permalink)
Mr. Blue Tape
A problem with rubber is that it can bend too much or worse, wobble and oscillate under airflow and that can create more turbulence than you may care for.
Since you've go so much of the front belly panned, a front air dam is probably not necessary. Front/side/rear wheel fairings might be helpful but conversely will entail more work on your part. (My Scion also has those little tabs ahead of the front wheels -- also a mini pan under the fender)
My 5 pillars of fuel efficiency:- driving style
- aerodynamics
- tires
- weight reduction
- engine maintenance
08-13-2008, 02:14 PM
#13 (permalink)
Hi,
A general comment about inside vs outside blocks:
I have noticed a (small) difference between taping (the outside) in courses starting at the bottom of the grill vs starting at the top. The only difference is the direction of the overlap -- the air is catching and lifting the seam if you start at the bottom, and this then drags a bit more!
So, if that small detail makes a difference, then blocking the inside of the grill can't be as effective as blocking the outside.
08-13-2008, 02:17 PM
#14 (permalink)
VIVA LA MPG RESISTANCE
Heck of a job! Looks great and kudoos on the recycle!!!
08-13-2008, 03:33 PM
#15 (permalink)
That's sort of what I was thinking after reading a bunch of car magazine and other aerodynamic articles. It will likely increase my overall frontal area and counter the gains I'd see if I do the full belly pan.
Hi,
That's interesting on the overlap of the tape. I was thinking of trying some test runs with painters tape over the upper grill.... then with both grills taped ... and then both grills and fogs covered to see if the MPG changes at all. So go from bottom up .... that makes sense ... especially if the tape starts to lift at all.
08-27-2008, 01:50 PM
#16 (permalink)
Ultimate Fail
Very, very professional looking.
I really like these 'stealth' factory looking mods. that you guys are doing.
Thanks for posting pictures.
"You don't fail until you give up. You learn, and move on." - Christ
" Hypermiling is not going slow, it's driving with more intelligence." - UFO
08-27-2008, 02:13 PM
#17 (permalink)
Deadly Efficient
Originally Posted by Markmysite
I'm surprised that they're are not more Vibe/Matrix users doing the aero mods. I have found tons of info on other cars, but not much on these.
We're on our own, Markmysite.
Be watching for my new grilleblock...it's almost done..
06-07-2009, 01:07 PM
#18 (permalink)
Basjoos Wannabe
I'm wondering if anyone has thought of my idea for a grille block.
I was planning on using insulating foam sealant (the kind you get in a can) and squirting it into the gaps between the gaps on the grille. After time to let it harden, I would trim off the excess with a knife, paint it black to match the rest of the grille, then reinstall it. THe beauty of this idea, other than the cheapness of it, is it wouldn't be hard to push the foam out of the grille if I go into an overheating situation. But done right, I think it would look very clean.
Gotta love wife, kids, and car!
Originally Posted by jamesqf
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
12-26-2009, 02:33 PM
#19 (permalink)
the picture links are dead!!!
12-26-2009, 06:43 PM
#20 (permalink)
Cartegena Uno Champ
If anyone has copies of the pics upload them to the website as part of their posting, that way the site "integrity" (as in you can come back in the future and see it as it is now) is preserved. We get no zombie threads that way and info is shared in the most effective way.
2011 Toyota Aygo Go!
Disclaimer - Postings from this author may be total rubbish. All figures in Imperial MPG unless specified. Use at own risk. Shake before opening. Store in cool, dry place.
Originally Posted by Gabriel Voisin about FWD
The system has the following merits: 1) It makes it easier to lower the centre of gravity and bring it forward. 2) It will free us from that unbelievable stupidity:a transmission shaft and tunnel between the engine in front of the driver and the driven wheels. 3) Front wheel drive will increase the interior space of the body, reduce the car's weight and diminish the cost price 4)It will annoy 320Touring by just being better  .
How to post images in Ecomodder.
Reason: si = is/ is = in
The Following User Says Thank You to Arragonis For This Useful Post:
