Old 01-19-2015, 10:10 PM   #11 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I'd suggest this mod has the potential to increase FE depending on the vehicle/ usage. The main reason warm air increases FE is it reduces pumping losses., so warm air is less likely to help on throttle-less engines.
You might also find if your car is underpowered, the extra hp means you can get to cruise speed faster. I'd consider adding the spacer and then plumbing in a WAI that introduces warm air at low engine speeds/ low throttle openings.
Performance and economy
Old 01-20-2015, 04:09 PM   #12 (permalink)
TexasThunder Avg MPG 54 - '08 Toyota Prius Base
Still need a little more background information. How difficult and or challenging is this material to cut/trim out...? If buy/purchase from ebay I know I want the thinner thickness to match current gasket(very thin).... How do you chose a grade kinda more than one to choose from? Is bakelite and phenolic interchangeable.,..?
