Old 01-02-2010, 12:01 PM   #1 (permalink)
Gen II Prianista
Rokeby's Avatar
Pickup Tail Gate Up or Down... A Scientific Explanation
More info with a scientific basis... is it the last word?
Journal of Wind Engineering and Industrial Aerodynamics
Volume 98, Issue 2, February 2010, Pages 100-112
Experimental study of a pickup truck near wake
Abstract
The present study focuses on the aerodynamics of pickup trucks. The flow
about a generic pickup truck has been documented experimentally. The main
objective is to gain a better understanding of the pickup truck aerodynamics
through mean and unsteady pressure measurements as well as detailed flow
field measurements using particle image velocimetry (PIV). Of particular
interest and complexity are the symmetric and asymmetric separated vortex
flows which develop behind the cab and the tailgate.
A secondary objective is to obtain a comprehensive experimental data set
for validation of computational fluid dynamics (CFD) models. The
experiments were conducted at Reynolds numbers in the range of 5–
8.5×105 in an open return wind tunnel equipped with two-frame digital PIV
system.
The mean pressure results of the pickup truck show that the pressure
outside the tailgate is higher than inside the tailgate suggesting that the
tailgate reduces aerodynamic drag. The root-mean-square (rms) values of
pressure fluctuations at the cab back is very low and increases significantly
towards the back of the bed and the tailgate top edge. Pressure fluctuation
spectra indicate a spectral peak at a Strouhal number of 0.07.
Velocity field measurements of the near wake flow show a relatively
quiet region behind the cab and no recirculating flow region in the symmetry
plane behind the tailgate. Instead there is a strong downwash at the
symmetry plane behind the tailgate. This downwash is due to the existence
of a pair of counter-rotating vortices downstream of the tailgate. The
downwash promotes attached flow behind the tailgate, thus resulting in a
pressure recovery that reduces drag.
ScienceDirect - Journal of Wind Engineering and Industrial Aerodynamics : Experimental study of a pickup truck near wake
Old 01-02-2010, 12:12 PM   #2 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 58.76 mpg (US)
Dusty - '89 Bronco XLT
90 day: 13.89 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 18.03 mpg (US)
Well then, there you go. That explains a lot.
2006 3500 Dodge QC/FB 5.9 handshaker
Old 01-02-2010, 12:32 PM   #3 (permalink)
Another damn paywalled article!
Old 01-02-2010, 12:48 PM   #4 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Insight
90 day: 98.7 mpg (US)
I got a good laugh out of that!!
Maybe this will help...
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off?
Jim.
Old 01-02-2010, 12:59 PM   #5 (permalink)
Gen II Prianista
Rokeby's Avatar
I did a lot of poking around the web trying to get around the "paywall" to see
the entire study. I was unsuccessful.
However, I did find that a one year, 12 issue subscription to The Journal Of
Wind Engineering & Industrial Aerodynamics
costs a mere ...
$3628.37.
I am at a loss to understand the business plan on this.
OK, LOTF is an appropriate response:
Originally Posted by 3-Wheeler View Post
Jim,
Thank you. I searched EM before starting this thread and found that one.
Because this study has a different point of origin and a different
methodology, I feel it deserves to be considered on it's own.
Old 01-03-2010, 01:50 AM   #6 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
If it costs that much, it must be valid...
Old 01-04-2010, 04:28 PM   #7 (permalink)
more
Abstract
system.
More de-fenestrated scientists operating in a vacuum,-issing away valuable research time and resources.
Please someone,buy them a window and show them how to use a search engine on the internet.
Kammbacks & tail aero info Bearleener Aerodynamics 30 07-22-2010 06:56 PM
