Old 07-24-2008, 12:48 PM   #21 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
Aero pickup bed plus rounded tail
Nissan Versa Aeromods
Old 07-24-2008, 04:15 PM   #22 (permalink)
basic re- design
Originally Posted by extragoode View Post
What exactly is meant by basic redesign? Buy a car?
You have to put the research in context of the state-of-the-art in pickup design at the time the paper was published(1988).You could take a current production truck and aero-mod it to get a 20% drag reduction,or the carmakers could design more aerodynamically efficient production pickups with 20% less drag.
That's the context.
Old 07-24-2008, 07:43 PM   #23 (permalink)
Looks like a K-back would do better than the curved back...
Old 07-25-2008, 09:59 AM   #24 (permalink)
Oden - '00 Frontier Crew Cab
Pickups
90 day: 21.99 mpg (US)
Malinda(WJ) - '03 Grand Cherokee Limited
90 day: 15.28 mpg (US)
Nerdcycle - '81 CM400E
Motorcycle
90 day: 53.8 mpg (US)
Bumblebee - '08 V3
Motorcycle
90 day: 69.17 mpg (US)
That's the context.
So trucks have been redesigned (comparing an '88 tacoma to a '08 tacoma) for the better and it might be a 20% improvement, but are the auto makers still "redesigning" pickups or is the best option now just an aeroshell?
Old 07-25-2008, 02:47 PM   #25 (permalink)
K-Back
The K-back yielded Kamm Cd0.37 on the Mercedes chassis.I prefer Cd0.32.
Old 07-25-2008, 03:02 PM   #26 (permalink)
20%
I don't think "Tacoma" existed in 1988.I think Toyota just called their pickup a Truck.A friend has a '93 Toyota,and it's architecture is very similar to the T-100,which is rated by Toyota at Cd0.44.---------------------------GM dropped the Cd on the S-10,from 0.485 to 0.42 in it's last incarnation ( about a 13.5% drop) I don't know what the older Toyota was.------------------------------ I think the spirit of the "re-design" comment,is that for existing technology of the day,and given what was understood about pickup aero,that a new softened model could easily pull off a Cd which was 20% less than models of that day (1988).I did a 74% reduction with the T-100.
Old 09-02-2008, 04:49 PM   #27 (permalink)
Tailgate up or down
The answer is simple. Keep your tailgate up. I did a series of wind tunnel tests on full-sized pickups in the 30-ft-wide, 30-ft-high test section of the NRC Low Speed Wind tunnel in Ottawa, Canada to investigate this issue. The results almost always showed that the tailgate up was best. With an 8-ft box, having the tailgate down or off decreased the drag coefficient (CD) by about 0.003 in a CD 0f 0.50. With the shorter boxes found with crew and extended cabs (6 ft & 4.5 ft), the drag coefficient was increased by up to 0.025 when the tailgate was of and a little less with it down. Adding a mesh tailgate instead of a solid one increased the CD by another 0.025, to a total of 0.05 above tailgate up. I would expect that any similarly porous tailgate would also increase drag. Since the gain of 0.003 is extremely small, it would not seem worth doing considering the loss of utility. Putting the tailgate down is a real loser since it is unsafe to following traffic and increases drag.
There you have it: keep your tailgate up.
SAE report: Pickup Truck tailgate aerodynamics... better up, down, or off? MetroMPG Aerodynamics 5 11-17-2011 02:35 PM
Test: F-150 pickup "cap on" vs. "cap off" @ 60 mph MetroMPG Aerodynamics 17 11-17-2011 01:44 PM
Report: Improving the Aero Characteristics of a Dodge Ram Pickup Truck MetroMPG Aerodynamics 34 11-12-2011 11:45 AM
Large Pickup Aerodynamic Mods buckyball Aerodynamics 43 08-02-2008 05:49 PM
More Pickup truck Aero bennelson Aerodynamics 16 05-13-2008 09:32 PM
