03-21-2014, 12:24 AM
#21 (permalink)
kach22i -- When the white pickup passes it's just like the ending of the movie Vanishing Point.
I think the half-tonneau question is explained by this, the augmented coanda nozzle:
The cavity is about as long as it is tall, and contains a bubble of air about the size of a hay bale that is spinning. If the bottom was half-rounded instead of filled with batteries or whatever it would be optimized.
Edit: Xist -- Possibly Twerks=T-100. Compound curved?
Reason: Edit:
03-21-2014, 06:11 PM
#22 (permalink)
1/2-tonneau
I think it was Sport Truck Magazine that interviewed the industry aero gurus around early 90s.
The operation of the 1/2-tonneau was explained as :
*the low pressure of the locked-vortex is telegraphed under the cover to the inner face of the tailgate.
*The delta-P across the gate is more favorable than with a closed,100% tonneau.
*It's this delta-P which gives the aero advantage.
*it's half the weight
*it allows access into the bed
03-21-2014, 07:10 PM
#23 (permalink)
The would be an interesting test for someone with a pickup truck:
• No mid-wall
• Flat mid-wall
• Curved mid-wall
03-22-2014, 01:17 PM
#24 (permalink)
test
• No mid-wall
• Flat mid-wall
• Curved mid-wall
Anyone with an OBD-II pickup could do a set of quick and dirty back-to-back runs and establish an MPG pattern with the three configurations.Volunteers?
03-22-2014, 10:45 PM
#25 (permalink)
Somewhere on this forum is the comment that a half-tonneau bed cover "equalizes" the pressure fore & aft of the tailgate.
03-23-2014, 02:44 AM
#26 (permalink)
Grogu - '12 Toyota Tacoma Base regular cab 4x4 90 day: 23.3 mpg (US)
I'm tempted to screw a piece of plywood to my truck bed now. I wonder how much bed length has to do with the CD measurements. Is an 8' optimal over a 6'? I'm assuming the longer the better ( at least with bullets longer heavier bullets have a higher ballistic coefficient or CD).
03-23-2014, 02:46 AM
#27 (permalink)
What's the mid wall? From the front half of the tonneau to the bed? What if its left open there?
03-24-2014, 02:51 PM
#28 (permalink)
8' vs 6'
The longer bed provides the (rearwards facing step) geometry which better supports flow re-attachment and vortex capture without reversed flow entering from behind.
03-24-2014, 02:57 PM
#29 (permalink)
mid wall
The mid wall is as you imagine,projecting down to the box floor from the front edge of the 1/2-tonneau.
The patent reflects a free opening underneath to the inner gate face.It's performance is predicated upon this feature.
Someone has done a CFD analysis with the mid wall.It's posted somewhere at this forum.Don't know where.
03-24-2014, 04:39 PM
#30 (permalink)
15 Toyota Prius Three with solar roof - rear diffuser
08 Ferd Escape 2wd 4cyl - stock
85 Volvo 245 lowered with IPD springs and Bilsteins
The Following 2 Users Say Thank You to Oceanic815 For This Useful Post:
