Old 04-22-2008, 01:13 AM   #11 (permalink)
Originally Posted by brucey View Post
Yeah, slightly. I put some "ribs" across so it could only conform so much. It held up quite well for being all tape. Rode the interstate for an hour or so in a pretty hard rain storm.
You might consider using longerons over the ribs, made of PVC pipe, then pull the plastic sheet snug. Fiberglass or aluminum tube tent poles as used in dome tents would work well, too.
Or, dacron works well, is light and strong, and comes in lots of colors. It is heat-shrinkable, so once you get the envelope over the longerons, you can pull it taught and wrinkle free by holding a hot clothes iron up next to the fabric (but don't actually touch the fabric).
Homebuilt airplane guys have used this stuff for decades, to good effect. Once you get the shape you want, you can dope the fabric to make it waterproof.
Old 04-22-2008, 04:12 AM   #12 (permalink)
OfficeLinebacker's Avatar
I think bending back is OK as long as the distance between the end of the airdam and the pavement is less than the lowest hanging underbody stuff.
Eventually I want to do an undercar venturi so that I can bleed engine compartment air and wheel turbulence into it. Using side skirts.
Old 04-22-2008, 06:17 PM   #13 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Me and a friend did this:
Completely out of tape. Don't feel too bad. That cover helped tremendously, so now we're working on a solid one.
How much did that flap around?
I'm still trying to determine how solid a boat tail needs to be . .
Thanks
6 speed ALH TDI
Old 04-22-2008, 09:16 PM   #14 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Originally Posted by Arminius View Post
Originally Posted by donee View Post
Nope, they should not be removed from the car. They should be moved to the front of the wheel wells.
Touche!
Mee uh-gree! Wee doo tings leetle deefrenlee roun hear.
CarloSW2
American Solar Energy Society
Old 04-22-2008, 10:34 PM   #15 (permalink)
The rationale for the clear plastic things was that I just happened to have those two pieces of lexan.
One neat thing about the lexan things is that they flip down for hood access. They also flip up/down when I decelerate strongly depending on the speed (above a certain speed it flips up).
What, no comments on the orange brake calipers (got the can of paint on clearance and just tried it out FSAG).
I've since found another can of primer grey for even cheaper so that I can cover up the evidence.
Freakin' wife.
