Old 11-06-2008, 08:36 AM   #1 (permalink)
"Inconceivable"
moorecomp's Avatar
My ZX2 - '99 Escort ZX2
Team ZX2
90 day: 40.5 mpg (US)
Her RAV4 - '011 Rav4 4x4
90 day: 24.98 mpg (US)
Pics of my Spiffie.org MPGuino
All,
I finally got my Spiffie.org MPGuino working, and although it is not in an enclosure yet, here are some pics (Sorry for the poor quality phone camera):
I removed the polarization film and cut it up and rotated it to achieve the inverted effect.
This is where I mounted my buttons. It turned out very nice!
I hardwired it, I did not use the phone jack and flat wire. I did not like the wire coming out of the side, I want it to be as small as possible.
Now it is all about getting it calibrated and hoping it will help minimize the effects of the cold weather on my FE. This is a great project, and would recommend it to anyone who cannot afford a ScanGuage.
moorecomp
Mancelona, MI
Old 11-06-2008, 02:55 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Definitely like the button mounts,
Old 11-14-2008, 12:12 PM   #3 (permalink)
MR2 Turbo - '93 MR2 Turbo
90 day: 28.28 mpg (US)
Are those the buttons that came with the kit? How did you mount them to your trim so they were solid? If you cant find an enclosure you like you could put a black vinyl sticker on the inside of the window, that way it hides everything when you look in from the outside of the car. Looks Great, Cant wait to get mine.......still on back order
ERIK
Old 11-14-2008, 12:43 PM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Thats cool with the buttons, Ill have to see how you did it. I might do something like that with mine in the 6000 wagon. Im thinking of using an iduino, theres a perfect spot in the dash piece next to the vent and shift indicator and the freeduino would probably be too big.
Also you can see the cruise buttons I made last year from an old end mill container. It works. For this car I dont care so much, its my winter beater.
Winter daily driver, parked most days right now
Summer daily driver
Old 11-14-2008, 01:32 PM   #5 (permalink)
"Inconceivable"
moorecomp's Avatar
Team ZX2
Yes, those are the buttons that came in the kit. I picked up a project board from the local RS and cut it down to fit. It is secured with hot glue to the inside of the trim piece. I know how you feel, waited 30 days for mine
I am getting the calibration down, took a drive down to Cadillac today and tweaked the VSS setting. Looks like I am within about .2 miles between the tripmeter and the MPGuino after 100 miles. MPG's still suck due to the weather tho.
Here's pics:
Topside of the trim piece. The hardest part was locating the 1/8" holes accurately. I had to use a 1/2" dia. drill on the botton side to create a recess for the body of the switches, as the buttons were not high enough to stick through the thick plastic far enough.
Bottom of the trim piece over steering wheel area. Hot glued project board with buttons to it.
Quick and dirty case made from cardboard, covered with vinyl and wide electrical tape. Price was right.
moorecomp
Mancelona, MI
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 03:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 05:35 PM
speed on mpguino fluctuates briansavka OpenGauge / MPGuino FE computer 1 08-01-2008 11:06 AM
Pics of my aero tweaks on 2000 Camry OfficeLinebacker Aerodynamics 14 04-22-2008 10:34 PM
