Old 01-06-2011, 01:06 PM   #1 (permalink)
VW Mk4 Golf Estate 1.9SDI
Aunt Bessie - '00 Golf Estate SDI
90 day: 52.38 mpg (US)
Planned mods to my Golf 4 Estate (stationwagon)
Go here to have a look:
golf.citrusdm.com
If you only see one pic, click on it to bring up the other 'after' shot.
*Disclaimer: That's not my car, I have a black one but I don't have any pics of it.
The Following User Says Thank You to 1.9SDI For This Useful Post:
JasonG (01-06-2011)
Old 01-06-2011, 04:28 PM   #2 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
90 day: 51.68 mpg (US)
Looks like a good start. A 3" suspension drop may be more for looks than for aerodynamics. You would probably get more bang for the buck by doing a full belly pan at stock ride height. These cars are already pretty low and broken oil pans are not uncommon on lowered cars.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
Old 01-06-2011, 05:41 PM   #3 (permalink)
I have a feeling you could be right. Perhaps 2" would be more prudent? I have a skid plate on already - it's a standard part as far as I can make out. The replacent suspension I've already bought is fully adjustable coil-overs so I can adjust ride height as necessary. The main point is getting air to go anywhere but underneath.
Old 01-06-2011, 06:57 PM   #4 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
That just makes me want one even more.
6 more months of saving and I should be able to get one.
Look at weatherspotter and his brother's rides to see how good wagons look eccomodded.
(sorry to _______ for forgetting your username.)
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 01-07-2011, 06:49 PM   #5 (permalink)
Thanks Jason, how do I look at Weather Spotter's brothers' car?
Good luck getting your own. I didn't like it much when I first got it but I love it now.
Old 01-07-2011, 09:52 PM   #6 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
Look at some of weatherspotters threads, his brother usually is there.
Support Bennelson !
Old 01-07-2011, 11:25 PM   #7 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
I have the aero trix (heavily modded 2006 matrix). My bother (soulster) has a mostly stock Kia soul and does not like the look of my car .
I will read through the thread and add my thoughts, I just wanted to clear up who has the car modding experience
Old 01-07-2011, 11:42 PM   #8 (permalink)
Wiki Mod
I like your car choice, wagons are nice mix between people and cargo and MPG
Mod tips (links are to our wiki mod page for that mod):
1. grill block is a cheep easy first mod. Grill block partial or full - EcoModder
2. smooth wheel covers Smooth wheel covers - EcoModder
3. belly pan Belly pan - EcoModder
4. Rear wheel skirts. Rear wheel skirts - EcoModder
5. side mirror delete. Side mirrors - EcoModder
6. Tire pressure to max sidewall. Increase tire pressure to max sidewall - EcoModder
7. Scangauge ScanGauge OBD-II computer - EcoModder
The first 7 are relatively cheep and easy to do. 8- 10 are harder but sill very doable.
8. Kill switch. Engine kill switch - EcoModder
9. Kammback. Partial Kammback - EcoModder
10. roof rack removal. Roof rack - EcoModder
11 Full boat tail. Full boat tail - EcoModder
this one is harder and will take some $$$ and time commitment. I just did it and it took me a strait week of work and about $300.
Issues with lowering:
1. will prematurely wear out your half shafts. I have a brother who tests them at work, keep the angle the same. Any change will kill them 2-3x faster.
2. reduces ability to go over debris in road
3. reduces ability to drive through snow (might or might not be an issue for you, I need 6-8" in the winter)
before lowering a car I would make a air dam to the same height and see if that scrapes or if it helps. It is also a cheaper way to get the same gain. Front air dam - EcoModder
Is the car a gas or not?
Manual or not?
I hope this gives you some food for thought. I would also look through the other mods on our wiki, it will give you plenty to think about
The Following User Says Thank You to Weather Spotter For This Useful Post:
1.9SDI (01-09-2011)
Old 01-08-2011, 05:53 AM   #9 (permalink)
Thanks WS, I've got a few mods lined up but I'm waiting on the delivery of my ScanGuageII. Without that I don't know what I'm improving on.
I quite like the look of your car - persuading my girlfriend to get in something like that s a different matter entirely!
I have a post in the Introductions section that lists all my planned mods but I've also been wondering about hydrogen injection. Any thoughts?
Old 01-08-2011, 06:57 AM   #10 (permalink)
Chug - '96 Polo CL
90 day: 49.42 mpg (US)
Hydrogen injectors are placebos really, takes more current from the alt than produces extra power/FE to compensate
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
