Old 06-05-2008, 11:53 AM   #21 (permalink)
Loving my blueberry
cwarnar's Avatar
Altimax - '98 Altima GXE
90 day: 32.88 mpg (US)
The Wan - '07 Sienna CE
90 day: 22.81 mpg (US)
Originally Posted by i_am_socket View Post
Quick and dirty gimping:
That looks awesome... I guess I have a summer project.
Am I going to be able to use chloroplast or am I actually going to need something fabricated?
Old 06-05-2008, 12:04 PM   #22 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
I would do it with tape and cardboard (unless you have some coroplas signs around) and try it out for a while..
If it was okay (no over-heating), then work on a more permanent solution.
Cheers,
Rich
Old 06-05-2008, 12:17 PM   #23 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Civic DX
90 day: 33.29 mpg (US)
I actually kind of prefer the pink insulation foam you can get at home depot simply because it's cheap and very structurally sound so you don't have to worry about flapping in the wind and what not. The only down side is that, unless you stack multiple on top of each other and shave to appropriate curvature, it's going to be flat, and remain that way. The good news is, is that they come in big sheets and to cover holes you don't need much so one sheet usually does the trick.
Old 06-05-2008, 12:21 PM   #24 (permalink)
Loving my blueberry
cwarnar's Avatar
That's good stuff. I am also pricing out springs and struts for lower the car, 1-1.5".
Would a body kit side skirts and and rear bumper help out as well:
Old 06-05-2008, 12:27 PM   #25 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
With the clean look of the smoothed out front, I'd avoid the ricey kits. Go smooth or foam up some mini-tails for the wheels and a pan for the rear if it's pretty scoopy under there.
Old 06-05-2008, 12:34 PM   #26 (permalink)
Loving my blueberry
cwarnar's Avatar
Ya, I figured as much, plus the saving wouldn't justify the cost of install and paint.
Old 06-05-2008, 12:44 PM   #27 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
the foam is the lightest most easly moded way to make mods.. it shapes really easy, then if you really want it pretty bondo it and sand it down and paint it..
You can usually get sheet up to 1" thick.. remember get the pink stuff... the white stuff desolves with just paint on it
Old 06-05-2008, 04:10 PM   #28 (permalink)
Loving my blueberry
cwarnar's Avatar
In regards to full moon wheel covers over my existing steelies, has anyone tried any of these:
http://www.hubcapmike.com/rdc01-15.html
http://www.hub-cap.com/universalhubcaps/15/RD-15.htm
The bonus is they are stainless steel. I also hope they work on my existing steelies:
Old 06-05-2008, 07:02 PM   #29 (permalink)
Bicycle Junky
NoCO2's Avatar
I just made a grill block for my Camry about 30 minutes ago and mounted it. Made it out of the pink insulation board ($10 for an 8'x3' sheet of half inch thick stuff). I used cardboard to make a template and then transfered it over to the foam board when I got it right. Then I just took sand paper to it to do the fine fitting part and then painted it to match my car with gloss spray paint...viola, done, 1 hour.
If I start seeing some decent FE gains from this and the belly pan I'm making, I'll be sure to put up pics and results as far as gains are concerned and I'm planning on attaching it more permanently as well. Right now it's held on with packing tape, which, oddly enough, not only is clear so it doesn't show up, but sticks to the foam better then duct tape which sorta surprised me, but I had to use it to cover some gaps that got made from a miss-cut and it stuck great, so I used it for the rest of it to hold it in place.
Old 06-06-2008, 10:45 AM   #30 (permalink)
Ex-lurker
My whole grill block IS clear packing tape; took my fiance almost 2 weeks to notice it
List of aero mods you can do to your vehicle MetroMPG Aerodynamics 72 01-05-2012 01:36 PM
Ford Fusion aero mods: Cd from 0.34 to 0.21 MetroMPG Aerodynamics 35 08-13-2011 02:39 PM
Chevy Cobalt (E85) Bonneville speed record (aero mods) MetroMPG Aerodynamics 16 06-15-2009 04:50 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
2006 in review: mods vs. technique. And the winner is... MetroMPG Hypermiling / EcoDriver's Ed 16 12-10-2007 08:46 AM
