01-25-2010, 01:35 PM
Moderate your Moderation.
Plastic engines
I searched for it, but I didn't find anything here, and while checking out some of the archives at The Knee Slider, I found an article about plastic engines possibly being a viable alternative for automobile/motorcycle engines of current production types.
Article follows:
Plastic Engines – We Have the Technology – Is Anyone Interested?
01-25-2010, 01:41 PM
First comment -
From the looks, that block is just that - a block. It would seem that the primary friction/heat parts of the block will not be replaced, and this is discussed in the article.
It seems like, if we can assume anything from that image, the bearing surfaces and piston sleeves will be part of a secondary "bed plate" that is either fastened/adhered to the plastic block "casing" (if you will).
If I might add another point of discussion to this: What about the availability of self-lubricating plastics? Would they be viable for use in low-speed engine applications (Sub-1000 RPM max) where low heat and power generation are required?
What about applications for air-engines? How about plastic parts for the parts of electric motors that aren't required to be metal by design?
What exactly are the possibilities of manufactured plastic components?
01-25-2010, 01:46 PM
...beats walking...
...I remember reading that article. At the time, I had a '72 Pinto with that Ford-of-Britain (FOB) 1.6L engine...got 36 mpg at typical 55 mph, of course, I'd done a few tweeks like change the stock 3.55:1 axle to 3.18:1; switch from breaker points to fully electronic ignition; and installed a "tri-Y" header from a Cortina.
• 2011 Chevrolet Cruze LTZ 1.4LT 6A
• 2009 Pontiac Vibe 1.8L/SFI 4A
• 2004 Pontiac Vibe 1.8L/MFI 4A
• 2003 Ford Focus ZX5 2.0L/Zetec 4A
• 1971 Dodge Charger 318 3A
• 1970½ Plymouth AAR 'Cuda 340/6BBL 4M
• 1968 Dodge Charger 383 3A
• 1967 Plymouth Barracuda Formula S 383 4M
• 1965 Plymouth Barracuda Formula S 273 4M
01-25-2010, 04:05 PM
a while back I got the notion that molded plastic vane-type stirling engines (with flexible vanes) could be built into the wheels of cars and replaced/recycled after 10,000 miles or whenever their performance begins to suffer.
but then i remembered that i'm not in charge of jack squat and even if i had the cure for cancer written on a napkin i wouldn't have a clue how to start a business making it.
2002 WJ Overland E85/gas flex
2002 Motobecane 700DS
1978 ChevroLegs
01-25-2010, 04:47 PM
Carbon fibre can be engineered to take the stresses involved and ceramic coatings can deal with the heat and bedplates etc to take the bearings will handle that.
I suggest it is more a case of what will it cost , rather than can it be made to work.
Even those very familiar with the technology (Ferrari for example) have yet to implement it beyond the cosmetic applications.
Pete.
01-25-2010, 05:29 PM
ooo ooo ooo ah ah ah
Tough to beat plain ol ancient cast iron for cylinders. Hasn't been done yet that I'm aware of.
01-25-2010, 05:30 PM
epic stock master
my accord has a pizza box under the hood. with hho.
01-25-2010, 06:23 PM
Did you read the second post? They're using the composite for a block casing, then adding in sleeves and a bed pan for the bearings/pistons. The base castings are plastic, but there's still iron in the block. They're claiming a weight savings up to 20-30% over aluminum engines, though. Significant.
01-25-2010, 06:42 PM
#9 (permalink)
...beats walking...
...ie: a "plastic" spider holding "cast iron" sleaves and bearings in their proper locations.
01-25-2010, 07:54 PM
#10 (permalink)
Yes I did read it. Just sayin.
