Old 02-04-2013, 04:28 PM   #11 (permalink)
Learning Aeromodding
myrefugeisintheLord's Avatar
Metro - '93 Geo Metro 4 door hatchback
90 day: 35.26 mpg (US)
I would agree. My CRX has a steeper hatch angle, yet there has been tuft testing to prove that the air is attached to the hatch. (Which was a selling point to me.)
Example:
I'd go with that last concept you had Razor. You might even look into whether it would be good to taper up that last angle a bit, like the CRX too. ???
Oh, will you be keeping the spare tire on? Your last concept might not allow for one.
The Following User Says Thank You to myrefugeisintheLord For This Useful Post:
razor02097 (02-05-2013)
Old 02-04-2013, 04:34 PM   #12 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Consider tapering the sides in as well. You can probably get more wake reduction that way than you can vertically, since there are two sides.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
Old 02-04-2013, 07:03 PM   #13 (permalink)
90 day: 47.72 mpg (US)
The windshield is pretty much upright and the roof is flat. Maybe put a curved plate or bulge on top to make the transition more fluent. Further back it can already bend down a bit so the rear section can bend down further without detaching the airflow.
In the whole it should look a bit like the Insight's and Prius' roof line, only considerably higher.
Old 02-05-2013, 11:06 AM   #14 (permalink)
razor02097's Avatar
Tetanus - '95 Geo Tracker 4WD Base
90 day: 29.43 mpg (US)
300 - '82 Suzuki GS300 L
Last 3: 60.78 mpg (US)
Jeep - '98 Jeep XJ Cherokee Limited
90 day: 12.82 mpg (US)
no spare tire I have a pump, tire plugs and patches and a bottle of slime. I took the jack, tire and brackets out which saved almost 72lbs. The rear seat belt towers are gone as well as the rear seat. I essentially have a 2 seater with a good size cargo area. Good ideas about tapering in the sides also.
Project Avalon: E bike build
