Old 01-04-2010, 12:44 AM   #1 (permalink)
Arrow pls delete
admin delete
Old 01-04-2010, 02:23 AM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
In short, yes. It will fit. They're "universal" fit to the OE exhaust.
You can probably find a cheaper one, or one that comes in a package deal with something else, though. Look a bit more on eBay, they're around.
The Following User Says Thank You to Christ For This Useful Post:
EG-VX-Driver (01-05-2010)
Old 01-04-2010, 12:09 PM   #3 (permalink)
?wtf.
Old 01-04-2010, 12:14 PM   #4 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
You need to contact the seller and ask these questions.
The Following User Says Thank You to thatguitarguy For This Useful Post:
EG-VX-Driver (01-04-2010)
Old 01-04-2010, 12:45 PM   #5 (permalink)
But i wanna know did anyone ever installed a Preformance header on their Civic VXs, i need to know what brand is a direct bolt to the oem piping on without the welding etc.....
some brands say i need to cut and weld.
Old 01-04-2010, 01:51 PM   #6 (permalink)
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
GOod luck man should sound pretty nice on there
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
The Following User Says Thank You to Domman56 For This Useful Post:
Old 01-04-2010, 06:47 PM   #7 (permalink)
Steve - '92 Festiva
Well, there is the issue that the VX's exhaust manifold is a short log-type, with a catalytic converter right there.
In order to retain a catalytic converter, you'll have to get one from another 5th gen model and fit it to your exhaust, then that header will fit.
The thing I don't remember is whether or not your downpipe is long enough to make up the distance between the catalytic converter and the rear pipe section. You'd have to look into that yourself.
Old 01-04-2010, 09:05 PM   #8 (permalink)
Sabrina - '91 190 E
Angel - '88 420SEL
just get a cat welded on further back in the exhaust
Tank:
Old 01-04-2010, 09:20 PM   #9 (permalink)
Steve - '92 Festiva
The cat bolts onto the header. It either bolts on in front of the engine, or it bolts on under the shifter assembly attached to the downpipe. In the case of the header that is displayed, it bolts on to the downpipe under the car.
The Following 2 Users Say Thank You to Christ For This Useful Post:
Domman56 (01-04-2010), EG-VX-Driver (01-05-2010)
Old 01-04-2010, 09:47 PM   #10 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
The main problem is your engine runs slow enough most of the time that a header like that is to big, it's like a little kid trying to play a tuba (really, exhaust systems fallow the same rules as wind insterments, not the rules of constant flow and restrictions) this engine also has lean burn and runs rather cool so it needs the catolitic converter close to the head to keep it hot enough to keep it from clogging and needing to be replaced.
How do I delete fuel/trip logs? Help! JJMunoz Forum News & Feedback 27 03-12-2011 11:14 PM
Alternator Delete, plus some old tricks combined TOOSTUBBORN2FAIL EcoModding Central 17 01-20-2011 10:37 AM
How to delete a car in the garage Undercover Forum News & Feedback 44 12-21-2010 07:24 PM
Cant delete fuel log entry bhazard Forum News & Feedback 3 07-16-2009 01:15 PM
Mirror Delete TheDon EcoModding Central 6 05-25-2008 11:48 PM
