Old 09-09-2011, 07:08 AM   #1 (permalink)
toc
Sonata97 - '97 Sonata GL
90 day: 25.96 mpg (US)
Pulsar - '03 Pulsar ST
90 day: 37.01 mpg (US)
POD Filter - good or bad?
How does a POD work - Hardtuned.net
I was reading that after curiously thinking about a pod filter.
A cold air intake would cause the car to use more fuel right?
What about air restriction - less restriction = more air, but won't it introduce more fuel to get the magical 14.7:1 ratio ?
Is there any FE benefit in a pod filter (instead of a WAI)?
Old 09-09-2011, 08:11 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
To keep the answer short and simple, a pod or high flow OEM replacement won't help or hurt fuel economy at all.
Old 09-09-2011, 09:07 AM   #3 (permalink)
A pod filter will do more harm than good in my experience. Air boxes are tuned for flow and resonance, and replacing them with a pod filter will hurt your throttle response and mid-range torque - costing mpg.
At WOT it may give you slightly more power, but it will hurt performance and MPG everywhere else.
Washable replacement filters like K&N aren't any benefit either from what I've seen, and usually don't filter as well as OEM-style pleated paper.
Old 09-09-2011, 09:16 AM   #4 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
One of the site's creators did a test and found no difference. You may get improvements on a tuned engine but as a direct replacement for OEM save your money.
No longer here. Bye, and good luck to all.
