07-08-2010, 10:39 PM
pooping bricks :)
ive learnt that some people cannot flush their toilet bowls by dumping a bucket of (gray)water in there.. so if youd like to save some water.. heres an idea... put 1 or 2 bricks inside your toilet water tank and voila
enjoy
07-09-2010, 12:17 AM
A shame mine simply would not flush like that. As it is, I've got the top off and I have to add more water to make it flush properly about half the time.
When I get my RV set up, whenever that will be, the gray water tank will be pumped directly into the toilet tank.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
07-09-2010, 12:38 AM
California had a rebate on low flow toilets. Put in a couple of Eco Drakes, 1.28 gal flush and the rebates paid for 3/4 the price of the toilets. Much better flushers than what I had before too.
Now there's actual semi-real testing done on toilets so you can get one that saves water AND still flushes well.
1992 Geo Metro, 1.0L 5spd, 413,000 miles on the original engine and trans!
- knuckles/hubs/brakes/13" wheels from a 2000 Metro
- running 175 70R13
- self built MPGuino
- averaging 51.7 MPG, 56.9MPG best tank.
07-09-2010, 12:50 AM
well since im in an appartment.. i have no intentions of changing my toilet bowl...
well it was just an idea
07-09-2010, 12:55 AM
ooo ooo ooo ah ah ah
Hmph. So it ain't just me.
Take that bucket o water and throw it in there straight down the chute- forget the tank. The extra inertia makes 'er go.
I make an effort to use a 5 qt ice cream pail of grey water whenever I remember to leave it in the sink to catch it.
07-09-2010, 01:25 AM
Bus - '94 School Bus huge Stupid - '01 Blazer LS 90 day: 21.38 mpg (US) hawk - '00 Superhawk
Thanks Frank,
I was wondering how the crapper they had wouldn't flush with gray water. My sis had a cabin without running water for a while and that is the way we flushed. I just couldn't figure out how it wasn't working for them.
On a side note, you can gain effectiveness in the pour-flush method if you don't directly hit the chute. It is called building a "head". Pouring off to the side will cause turbulence that will keep the water in the bowl longer, allowing it to fill and create a better siphon on the trap. Pouring directly in causes the trap flow to become turbulent (you dont want this) and it breaks up and pulls a poor siphon (doesn't flush well). good luck.
07-09-2010, 03:05 AM
wow.. good tip on that one.. i hate seeing chunks of last nights dinner floating about
07-09-2010, 05:40 AM
Be careful if your putting a brick or two in the water tank, some water tanks are not held to the wall very securely. The weight of a couple of bricks could be enough to pull the screws from the wall(Had it happen once).
Another option is to use either a zip-lock bag, or an old plastic paint tin, filled with water, in the tank.
07-09-2010, 07:46 AM
#9 (permalink)
aero guerrilla
I put bricks in the tank at my Mom's house many years back, but after 2-3 years they started to crumble (good material, eh?). I cleaned out the tank and put in 1 pint bottles filled with sand and water.
Piwoslaw's Peugeot 307sw modding thread
07-09-2010, 01:00 PM
#10 (permalink)
"Crush"
I have a semi-automated graywater system at my house.
Used laundry water goes through a sandfilter/marshplants, gravity fed into a big rubbermaid trough, and then gets pumped to the toilet with a well pump on a pressure switch.
When you flush the toilet, pressurized water starts pumping into it from the graywater tank.
It works great.
Read more at:
Ben's DIY Graywater System - EcoRenovator
