Old 12-03-2009, 12:24 AM   #11 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
I'm not aware of anyone that's done it publicly, but it's a matter of reasoning. If your T case has a low-end ratio of 10:1, and you flip it around, it's now 1:10, or .1:1.
Would be neat to see someone do it.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 12-03-2009, 10:04 AM   #12 (permalink)
Whoa. Sorry to go so long without posting in my own thread, but you know how the holidays can be.
Aero, I appreciate you digging up that issue for me. I'll see if I can't track down a copy later today.
Christ, I came across a thread about doing something similar. I'll find it and post it here later today, but basically the idea was to use a New Process 205 transfer case as an old-fashioned overdrive unit. It is only a 2:1 ratio, but that's a 50% reducer. Also, they can be found used for about $300.
Frank, the reason I don't try to re-gear the transmission and rear-end to accomplish the same thing is that there is no way that I could accomplish what I want at higher speeds without killing the low end. I have a low horsepower, relatively low RPM engine. At higher speeds, the engine has to maintain a high (for it) RPM. If I use an overdrive unit, it will increase my top end and allow me to keep the engine in its most effect RPM. If I lower the rear end ratio, or up the transmission ratios, it will lower the necessary RPM but negatively impact my top end and acceleration. Also, with what they charge for transmission work around here, I could almost buy that 3k gear vendors unit.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 05:04 AM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 11:41 PM
Longtime Lurker Looking for Miles ZX40 Electric Micro van mods & information rmay635703 Fossil Fuel Free 42 03-28-2010 03:24 PM
Civic DX-VP, Insight, or ??? RH77 General Efficiency Discussion 58 09-20-2009 01:22 PM
transmission determination - how to determine final drive ratio? gwahir EcoModding Central 5 01-12-2008 12:41 AM
