Old 05-28-2011, 06:24 PM   #1 (permalink)
Temp - '94 Civic EX
New Found Love - '89 CRX HF
Question Possible Kill Switch?
Hey,
Just wondering if this little guy will work as a kill switch?..._IGP4753.JPG
I took it out of a Playstation 2!
It has two prongs on the back and then two solder spots..
Id like it to work cause its so dang tiny.. It doesn't look to bad either...
Thanks!
Check out my project here---> My CRX Project
I am looking for an '88 or '89 Honda CRX HF for parts (mainly interior..)
Old 05-28-2011, 10:13 PM   #2 (permalink)
Aero Sol - '93 Del Sol GSR
90 day: 40.31 mpg (US)
yes that will work.
Old 06-01-2011, 03:13 PM   #3 (permalink)
mcmancuso's Avatar
Green Metro - '99 Metro LSi Sedan
90 day: 32.78 mpg (US)
Metro Vert - '91 Metro LSi Convertible
90 day: 50.52 mpg (US)
Personally I wanted a momentary switch for my fuel cut, since I wanted to just be able to release it when I wanted fuel. don't know if leaving it switched off may or may not be a safety issue as you will have to actively switch the gas back on...
here's mine:
Old 06-01-2011, 03:16 PM   #4 (permalink)
Temp - '94 Civic EX
Ya, but on long coasting you'd want to be able to just switch it off and not have to hold it wouldn't you?
Old 06-01-2011, 03:46 PM   #5 (permalink)
mcmancuso's Avatar
I actually have both (I use the switch for security, can't start the car with no gas ) but for 99% of the time I use it, I just use the pushbutton. It would have to be a LOOOONNNNGGGG (1mi or more) coast for it to be too long to use the momentary button, and around here anyway, there aren't any areas like that.
Old 06-01-2011, 03:53 PM   #6 (permalink)
Temp - '94 Civic EX
Can you post some pics of your switches?
Did you just double splice your wire to get both the switches in there?
Old 06-01-2011, 04:22 PM   #7 (permalink)
mcmancuso's Avatar
Wire runs from injector, to switch 1 then to switch 2 then to the injector driver circuit.
the other switch is just inside the glove box on the driver's side (I can reach it easily while driving):
the other switch is for my alarm system, I also lock the glove box via a key when its parked (its a convertible)
Old 06-01-2011, 04:41 PM   #8 (permalink)
Temp - '94 Civic EX
Nifty.. That is a good idea.. maybe ill have three kill switches with one in the glove box
Kinda like the idea of the switch in the shifter knob. Was that hard to do?
Old 06-01-2011, 04:54 PM   #9 (permalink)
mcmancuso's Avatar
A little since I had to drill a hole into the rubber, then cut a cavity big enough for the switch base into the plastic. I then filled it with RTV. pretty much followed the guide here but my switch's base was larger:
Geo Metro Fuel Injection Kill Switch
Personally I didn't use a relay, I just ran the injector wire to my switches, it works fine, but the relay is probably safer.
Old 06-01-2011, 05:17 PM   #10 (permalink)
Temp - '94 Civic EX
Hmm... Ill probly just keep it in the dash or maybe attached to the steering wheel in a clean way? Idk.. Ha.
