Old 04-29-2008, 03:21 PM   #11 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Any specs on the duration of the stock and xfi cams? From my understanding, duration is the bigger player when it comes to powerband manipulation.
Old 04-29-2008, 11:05 PM   #12 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
With the combination of specs posted here The lobe height of the base cam is 1.5911 and the lift is 330 so subtract those and you get 1.2611 for the base circle for the cam. The lobe height of the XFi is 1.5602 so subtract the base circle from that and it gives you 0.2991 so we can say the lift of the xfi is 300. Now I just need some time with a degree wheel on my engine or someone else can do it and get the measurements for the duration of the cam.
Searching around teamswift I got lucky and found this:
Suprf1y wrote:
I have added another profile to the 89-up 3cyl. cam list.
Due to a high amount of requests, I now have a 'fuel economy' cam. It is a profile with shorter duration, and lesser lift than the stock cam. This would be of benefit to somebody who uses their car primarily as a commuter vehicle. It is not a performance cam. In conjunction with a +10 timing advance sprocket, you will feel stronger bottom end power, and recieve superior overall fuel mileage.
Testing is underway to document the actual MPG gains, but this is a known quantity, and it works.
Lift is .305" (7.75mm), and duration at .050" is 184
I believe his cam is very similar to the xfi if not a direct regrind copy so I would take these numbers as close enough for anyone wanting to play with an engine analyzer program and see if they can come up with the perfect cam.
My Convertible Metro XFI Plug in Hybrid Project build log
Blackfly XFi? Cam swap! Update: swap completed MetroMPG EcoModding Central 19 06-04-2011 07:16 PM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 08:00 AM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
How to tell an XFi from a garden variety Metro MetroMPG General Efficiency Discussion 6 07-12-2008 11:48 PM
xfi metro camshaft gwahir EcoModding Central 9 12-21-2007 12:23 AM
