Old 11-14-2008, 11:06 PM   #11 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
Mine is also really high, something like 10.5% or so...
Speed is +1
Old 11-15-2008, 03:32 AM   #12 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
I've had the SG2 set at +8.0% gallons for a while, but my fill today was way off: 7.83 gal actual vs. 8.82 shown on the SG. That's 12.6% high, which suggests I actually need a *negative* offset to be accurate.
The 12.6% error just means you have to lower the 8% a little, not that you have to subtract 12.6 percentage points. According to some simple math 7% should be right on if your fillup was accurate. 7% is actually what I have been using (I reported 5% earlier) and it has been pretty close.
More choices...
Old 11-15-2008, 11:52 PM   #13 (permalink)
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
2002 Toyota Corolla S - 1ZZFE 1.8L engine: 9.9%+ on the Scan Gauge I.
This number is from many tanks of gas, and I can confidently say that this mileage figure is within 0.2% of actual mileage, every time.
Am I seeing a trend on the ~10%+ line here, or is it just a coincidence?
Darin, we may have you calling Ron about this . This would give an overinflated figure, right? One too many six packs in me to think about even this low-order math... perhaps in the morning...
American by right
Ecomodder by choice
Hypermiler by necessity
Old 11-16-2008, 08:26 PM   #14 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I filled up again today, after a long trip (750 km), and using a +3.0% fuel offset, the SG was still reporting more fuel used (6.68 gal) than the pump read (6.33 gal).
Are you sure about that? If I remove the 8% correction from the SG's calc for fuel consumed (8.82 gal., in post #10), then the un-corrected amount is 8.17 gallons (8.82 / 1.08). It's still higher than the actual fill amount of 7.83 gallons. Am I doing it wrong?
I'm going to drop it to 0% correction factor for tomorrow's leg of the trip. I'm still predicting it'll end up needing a negative correction.
I wonder why it has changed from a positive offset to a negative one.
Old 11-16-2008, 10:14 PM   #15 (permalink)
Renaissance Man
Formula413's Avatar
I think I had it wrong earlier. If you were using a correction factor of + 8% and the SGII reported 8.82 gallons used, that means that it actually thought you burned 8.17 gallons, and applied your chosen correction factor to come up with 8.82. So based on that you should be using a correction factor of - 4%, which is about what you estimated. So yeah, go with that. As to why the correction factor seems to change, that's a good question. Mine was pretty accurate at + 5%, now it seems to work best at + 7%. Perhaps it is seasonal, I.E. the SGII is unable to account for changes in air density from different temperatures? This wouldn't seem to make sense however since it has access to IAT data. Does anyone know exactly how the SGII comes up with it's fuel usage estimate?
More choices...
Old 11-18-2008, 11:39 AM   #16 (permalink)
Originally Posted by Formula413 View Post
As to why the correction factor seems to change, that's a good question. ... Does anyone know exactly how the SGII comes up with it's fuel usage estimate?
Aha! I think your question solved the riddle.
The SG calculates fuel consumption based on air consumption, and extrapolates fuel use with a formula based mostly on stoichiometric air-fuel ratios.
But I've changed my driving style. I used to do a LOT of pulse & glide (P&G), but now I mostly drive with load (DWL). In the Metro, P&G consists of a lot of non-stoichiometric, open loop acceleration. DWL keeps me in closed-loop stoich mode almost all the time.
So, the ScanGauge probably didn't know what the rich burn rate was/is, and obviously it was guessing wrong. It was underestimating it, which is why the offset that worked best when I was doing lots of P&G was +8%.
Also: maybe Linear Logic updated the SG's formula between versions? I've also gone from SG1 to SG2 since I first figured out that +8% offset.
Anyone else upgraded and noticed any difference?
Good reason to use a MPGuino.
Old 11-18-2008, 03:35 PM   #17 (permalink)
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 72.37 mpg (US)
1996 Civic DX (d16y7) manual 5
Fuel +8% (or +12% with e10)
P&G driving all the time.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
Old 11-18-2008, 04:13 PM   #18 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Originally Posted by PaleMelanesian View Post
(or +12% with e10)
That's an interesting observation that I didn't take into account. I'm sure the Winter-blend is now in effect, so the adjustment may be needed.
-Rick
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 11-18-2008, 04:16 PM   #19 (permalink)
Wayne G has registered a similar effect between summer/winter gas. We have the same year-round here, but a few months ago we switched to (almost) all E10 instead of straight gas.
Old 11-26-2008, 06:58 PM   #20 (permalink)
the Sheetbox - '96 Aspire
90 day: 39.43 mpg (US)
**based on the pic, I wonder what car can get 7mpg at 129MPH!!?
This gets 16mpg at race speeds, usually averaging over 110mph
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
Dealer says ScanGauge ruined my PCM and I can't use ScanGauge anymore Markmysite EcoModding Central 55 05-06-2010 07:31 AM
