Power loss above 2500RPM '96 Pulsar
Hey guys, just asking for some advice here. My brother has a 1996 Nissan Pulsar, and it's got some problems. When the revs hit around 2500RPM, there is a smooth but sudden loss of power. If you keep your foot on the accelerator, the revs hold, but drop slowly but surely. If you clutch/put the car into neutral for a short while, the problem subsides a bit, but issue still kicks in at around 2500RPM. Does anyone have any idea what the problem could be? We just returned from the mechanics, and they couldn't find anything wrong with the car, or any error codes in the ECU. Thanks!
Edit: BTW, this happens in every gear, and at all throttle positions. There are no problems when engine braking though.
