Old 10-28-2008, 10:10 PM   #11 (permalink)
Wow! Lots of ideas.
That Citation I mentioned, never had the bugs all worked out before I left that company. The boss intended that Chevy to be the beta unit for a mass produced or retrofit car, and as you say Ben, the same steering weather it was in ICE or EV mode, as a requirement
Remember that older manual steer cars often used less caster (I think the metro does, too), which decreases low speed steering effort for ease of parking. I wouldn't get carried away, and I'd reduce the caster, keeping at least 3-5 degrees for higher speed stability.
You could also slightly increase the diameter of the steering wheel, too.
Old 10-30-2008, 12:27 AM   #12 (permalink)
Beta-tested it to death!
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
Sunfire - '00 Sunfire
90 day: 26.44 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
A bypass for power steering? Sounds like a cool idea!
A few weeks ago, I fixed my gas laundry dryer. The problem was the coil that electronically opens and closes the gas valve.
Couldn't a similar electronic valve be used to open and close a bypass for power-steering?
Push a button, or flip a switch, and have power steering at will!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 12-02-2008, 02:13 PM   #13 (permalink)
arb
manual rack & pinion...
I removed the power steering unit (everything) from the 1992 Caravan I'm putting a 1.6L turbo diesel in. I replaced it with a new manual rack. It steers well at rest because the gears are different - 3 turns lock to lock for a P.S. and 4 turns for a manual. Here are some photos and description of what I did... half way down the page.
VW GTD :: View topic - 1.6L TD in a Dodge Caravan
The Following User Says Thank You to arb For This Useful Post:
dennyt (11-08-2010)
Old 12-02-2008, 04:14 PM   #14 (permalink)
dichotomous's Avatar
CivySi - '03 civic SI
90 day: 31.99 mpg (US)
my car has electric power steering, so does the S2000. shove one of those units in your car and be happy. it works when the key is in run mode, even with the engine off (though it pauses for the first turn for some reason)
Old 12-02-2008, 04:28 PM   #15 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Yah OK I'll just run out there and git oneuh them.
Old 12-02-2008, 04:42 PM   #16 (permalink)
well if you want electric power steering.... its a heck of a lot better solution than fitting an electric motor to a power steering pump. that will draw power all the time, the honda system only uses how much it needs when it needs it.
Old 12-02-2008, 05:28 PM   #17 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Does the ecu control it? I'd wager Honda's price for that pump and associated parts is more than I've got in my whole car!
Old 12-02-2008, 05:32 PM   #18 (permalink)
arb
Ford has electric pw steering too and will extend it to nearly all of their cars in the next couple of years because they want to be the leader in economy
Old 12-02-2008, 06:10 PM   #19 (permalink)
Wannabe greenie
The Clunker - '90 Accord EX sedan
90 day: 29.49 mpg (US)
Uranus - '04 Ion 2 sedan
90 day: 38.21 mpg (US)
Mountain Goat - '96 Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Maybe some kind of bypass valve to lighten up the steering, coupled with an A/C compressor clutch pulley. Flip a switch, and it freewheels the clutch and pulley, while releasing pressure on the pump so it turns more freely?
Old 08-04-2009, 10:15 PM   #20 (permalink)
Relevance is irrelevant!
bluetwo's Avatar
Civic EX - '00 Civic EX
Send a message via Yahoo to bluetwo
I've read about a few people who just removed their power steering belt and from the lack of posts about any problems they don't seem to be having any. Of course that doesn't mean there haven't been any complications, maybe it only means they didn't post about it.
Still.... I want to try it and I've been reading up a little. I didn't think much about different ratios or castor settings until I read this thread though. I had an 82 Prelude that turned wonderfully in parking lots and on the roads without any power steering.
Are there any mechanical issues that could come of a "power steering belt delete" and should one be worried about doing anything other than simply disconnecting the belt? I understand the weight savings that could occur if the PS pump was removed but I haven't looked closely at mine to see if it can just unbolt.
I'm talking about a 2000 Civic....
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 08:53 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 02:23 PM
"underdrive" power steering pump? gascort EcoModding Central 9 08-19-2008 10:36 PM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 01:42 AM
