Old 09-11-2009, 04:33 PM   #41 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Sorry to be a killjoy but...
I've read some physics threads on the subject of rotating mass and those factors you guys are quoting are really high. They calculated more like between 1.5:1 to 4:1 but so much depends on how far from the axis the weight is. ie. One lb of tire weight has more effect than 1lb of rim weight etc. It also depends how fast you are accelerating. If you are drag racing then it makes a big difference.
Physics thread:
Rotating Mass when keeping a minimum weight Text - Physics Forums Library
Tuner thread:
Reducing Rotating Mass: Ditching Dead Weight [Archive] - Bimmerforums - The Ultimate BMW Forum
I ran similar numbers for the M3 flywheel just to see how they'd come out. I'm calculating a 1% acceleration difference in 1st gear going from a 26lb fly to a 12 lb fly, ignoring all other rotational mass (gearbox, wheels, driveshaft, accessories, etc). In this case that's like dropping 31.5lbs off the car's weight, or 2.24lbs for each pound of rotational mass drop. This doesn't seem like the dramatic difference that people seem to feel.
The Following User Says Thank You to orange4boy For This Useful Post:
Christ (09-11-2009)
Old 09-11-2009, 06:22 PM   #42 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Yeah, see, I knew even I was wrong...
Old 09-11-2009, 06:47 PM   #43 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Everyone knew you were wrong from the start!
Just kidding.
I wonder if there's a good web calculator out there for calculating inertia etc?
Old 09-11-2009, 07:33 PM   #44 (permalink)
Steve - '92 Festiva
Eh, It happens!
I'm not the infallible one, ya know...
Old 09-11-2009, 10:28 PM   #45 (permalink)
Originally Posted by bennelson View Post
A bypass for power steering? Sounds like a cool idea!
A few weeks ago, I fixed my gas laundry dryer. The problem was the coil that electronically opens and closes the gas valve.
Couldn't a similar electronic valve be used to open and close a bypass for power-steering?
Bennelson,
Electric / hydraulic p/s units use exactly this method to achieve the result and a small processor attached to the steering column works out when the power is needed and how much.
As an aside the numbers from component supplier ZF (a main player in this area) suggest the fuel used just for conventional hydraulic p/s from a belt driven pump is around 0.5 litre/100 klms. The range varies depending on the application from about 0.2 to about 0.7.
Car makers would rather give up their first born than part with this sort of info in most cases.
Full electric systems draw about 35 amps at 12 Volts at full demand as a comparison.
Pete.
The Following User Says Thank You to Peter7307 For This Useful Post:
Sven7 (03-27-2012)
Old 09-12-2009, 01:57 PM   #46 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
420 watts. That's half a HP. The engine has to supply double that to the alternator so the engine will have to supply 1 hp at full load.
A 200-W electrical load accounts for about 0.4 km/L (.94mpg) in the FTP 75 cycle test.
Old 10-12-2009, 02:29 PM   #47 (permalink)
Route around the pump?
I've spent a fair amount of time now in my Contour in EOC, and I find that the steering effort is quite acceptable. Also, I think that--for safety reasons--it'd probably be best if steering effort were constant (so that an emergency situation can be dealt with w/o having to think "wait: am I in EOC or not?")
The PS pump is right out where I can touch it in my car, and the inlet and outlet lines are, too. Thus, it'd be a 10-minute job just to bypass the pump and allow it to freewheel.
What I need to know is if this would eventually cause the pump to sieze. Is the pump mechanism lubricated by the PS fluid? I don't want to do anything that would take out the serpentine and (egad!) timing belts when the PS pump siezes. I could just loop the pump to the resevoir to "get a feel" for power-free steering, but that wouldn't do much to reduce pumping losses.
Another possibility woudl be to grid off the fins/lobes/whatever that actually pump the fluid, so that what's left could spin, but not actually do anything, or create (virtually) any resistance.
Old 10-12-2009, 02:58 PM   #48 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
What? If you aren't taking the belt off the pump, there's no point in it.
Old 10-13-2009, 12:04 AM   #49 (permalink)
Yeah, I know there's no FE gain, but I thought I'd route pump output back to the resevoir for a tank or so, just to see how I tolerate the PS delete before I do anything irreversible.
If I do delete the pump, I'll have to either put an additional idle pulley in place of the PS pulley, or try to find a shorter serpentine belt w/ the same width.
Old 10-03-2010, 08:44 AM   #50 (permalink)
4ringcircus's Avatar
Ford Ranger - '97 Ranger XLT 4x4
I removed my belt for about a week. I could instantly feel the power improvement, but on a heavy 4x4 it was just too dangerous in tight situations.
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 07:53 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 01:23 PM
"underdrive" power steering pump? gascort EcoModding Central 9 08-19-2008 09:36 PM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 12:42 AM
