Old 10-03-2010, 09:49 AM   #51 (permalink)
Wiki Writer
bugler - '91 626
90 day: 35.89 mpg (US)
4ringcircus, I did the same thing as yourself and thought no way people cant drive around like this its way to much effort to turn. When i looked more into it i found if you remove the power steering hydraulic lines the effort becomes significantly easier. I am not sure about a 4x4 but for my car it worked well and i dont even notice the effort in steering (until i get into another car and turn with much more effort than i should).
have a look at the wiki if your interested in trying it out as i have put in some pictures and a how too instruction for the mod.
Power steering delete - EcoModder
Old 10-03-2010, 08:24 PM   #52 (permalink)
On my '95 Saturn TDI project, I just cut the lines off the fittings and used a piece of 3/8" fuel hose to loop between the two. For awhile I thought about trying to refit the VW power steering pump in a different location, but I found that I really didn't miss the power steering. It does take some effort at very low speed, but it's not a Herculean effort, either.
Old 03-26-2012, 11:17 AM   #53 (permalink)
bheadrick's Avatar
Nissan Sentra - '01 Sentra GXE
if your water pump is on the same belt, how do you go about removing the belt from the power steering? Can you get a smaller belt that doesn't have to go around the power steering pulley?
Old 03-26-2012, 04:20 PM   #54 (permalink)
50mph sur la 50
echo-francis's Avatar
echo-troll - '05 echo
90 day: 58.74 mpg (US)
i would like to take out my p/s belt and bypass the lines but can someone give me clearly instruction on aow to do this please (my power steering have is own belt)
Echo-Troll Modding Thread
Old 03-26-2012, 05:12 PM   #55 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Now I've done power steering delete for fuel economy gains, but I don't drive enough anymore to post any reports quickly.
Old 03-26-2012, 08:19 PM   #56 (permalink)
Vman455's Avatar
Little Red - '05 Civic EX
90 day: 48.29 mpg (US)
I did this last year on my car, which is similar to yours in that the power steering pump was run off its own belt. It's fairly simple (remove pump, belt, lines, and replace with a loop between the pressure and return lines at the rack, with an extra hose if you want a reservoir), and I followed this DIY: DIY: Removing Power Steering - Honda Civic Forum You'll need to figure out what size/thread the rack fittings are for your car before you can replace them, but the rest should be analogous.
Old 03-26-2012, 08:32 PM   #57 (permalink)
50mph sur la 50
what did you do with the power steering liquid?
Old 03-26-2012, 09:29 PM   #58 (permalink)
Black Knight - '94 Corolla
90 day: 61.92 mpg (US)
use it for weed killer.... J/K
Old 03-26-2012, 11:47 PM   #59 (permalink)
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
the brown goat - '03 impala base model
puddle jumper - '-1807 sidekick base model
energizer bunny - '86 trooper base model
Clifford the big red dog - '84 S-10 durango
cameo mobile - '91 trooper base or S model
road master - '86 pup base model
MPG+ pup - '81 pup DLX
pulled the belt on the side kick a year or more back.
its very light for a RWD suv, has narrow tires, with high pressers.
takes some force at a stop 60LB at the very very most, but really not that bad.
thus the mpg gane is in the less then 1 mpg range.
id gane more from a clutch fan swap out, than the P\S belt removal.
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
Old 03-27-2012, 11:06 AM   #60 (permalink)
Vman455's Avatar
I drained it into an old milk jug and mixed it in with my old motor oil the next time I changed it and brought it in for recycling. I do the same with coolant and other fluids that I can't legally dispose of, too.
I live in an apartment, so I don't have to worry about weeds!
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 07:53 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Removed '00 Civic power steering belt and got good results but... hondaworkshop EcoModding Central 8 10-07-2008 01:23 PM
"underdrive" power steering pump? gascort EcoModding Central 9 08-19-2008 09:36 PM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 12:42 AM
