Old 03-02-2009, 09:11 AM   #1 (permalink)
The Move - '99 Move Aero Down Custom XX
90 day: 29.89 mpg (US)
Send a message via AIM to Dust Send a message via Skype™ to Dust
AT power supply to bench power supply
I have found all the stuff is for ATX, and want to use the little AT power supply I got from school. ANy suggestions on where to look for instructions. It has a switch, but there is no "white" wire which supposedly all AT power supplies have.
Old 03-02-2009, 10:56 AM   #2 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
Instructions for what, to turn it on? Or for what wires provide certain voltages?
For pinouts, just google 'AT power supply pinout', and you'll get a lot of results, here's one that looks good.
I'm pretty sure every AT PSU I've owned had its' own power switch, whereas ATX PSU's require you to jump 2 wires if you're not connecting them to the motherboard. What brand PSU is it?
Old 03-02-2009, 05:40 PM   #3 (permalink)
The write-up I saw for AT supplies said tat I needed to cross a blue wire and a white wire, and I don't have a white one, so I am trying to figure out how to get it to turn on without a MB hooked up to it.
Old 03-02-2009, 07:00 PM   #4 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
You would just turn the switch on and you would have +/-5v +/-12v and grounds along with a power good wire and some other items rarely used.
You need to remember though, very old AT power supplies require a load resistor of sufficient size to turn on or an old hard drive or something with sufficient power load to bring them up, I have NEVER had an AT PSU that required anything other than a load to turn on, the power good line prevents the PSU from turning on by showing a voltage or a connection to ground, so if it isn't there then the PSU will turn on anyway. (assuming the supply is standard and not damaged)
Good Luck
Old 03-02-2009, 10:59 PM   #5 (permalink)
13.8 V / 15 A from a PC Power Supply
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 03-03-2009, 01:47 AM   #6 (permalink)
I have an extra HD and a bigger fan I will try to hook up and see what happens. I am kinda pissed at myself. I ruined a perfectly good PSU by trying to get some of the wires cleaned up. Had it wired up and had been using it, but it was time for me to cause problems for myself, since I had something to use it for that night.
Old 03-03-2009, 03:16 AM   #7 (permalink)
Hooked up the HD and still no love.
Old 03-03-2009, 09:31 AM   #8 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 City iDSI EXi
90 day: 47.47 mpg (US)
A certain minimum load on the main feedback output is always required for any SMPS to give a stable output - In most cases the auxiliary voltages are linked with the main output only through their output winding ratios. This situation leads to very poorly regulated auxiliary voltages, when the main feedback voltage is not loaded enough. There are smarter power supplies that try to cross-balance the feedback, but most cheap ones won't to to those lengths.
So, as I suspect, a fat wire-would power resistor (fat only for wimpy electronics guys) would be required on the main voltage to ensure stable outputs regulated enough.
Generally +5V is the main winding and 10 ohm 10W would be good ratings for the power resistor.
You would need the pins 14 and 15 on the ATX connector shorted to bring up the power supply
Old 03-03-2009, 11:12 AM   #9 (permalink)
rmay635703's Avatar
He has an AT power supply which gets hard wired on through an old contact switch, your comment on load resistor is accurate though.
I suspect that his paticular AT PSU required a load to operate, he attempted to fire with insufficient load and blew out the primary so now its non functional. (not all AT power supplies will survive being powered on without a decent load)
Can the OP try the PSU on a mobo to see if anything happens? My guess is the PSU gave up the ghost.
Anyway I have used old AT supplies for everything from battery chargers to lab power, it should not be real complex, you just need to take care that you always have sufficient load, also what MODEL and TYPE of AT PSU do you have? Are you positive it was functional before you tried using it?
Take a pic, maybe it is not truly an AT but a proprietary unit from a compaq, packard bell or the like.
Good Luck
P8
Pin Signal
1 Power Good
2 +5V or N.C.
3 +12V
4 -12V
5 Ground
6 Ground
P9
Pin Signal
1 Ground
2 Ground
3 -5V
4 +5V
5 +5V
6 +5V
Old 03-03-2009, 08:05 PM   #10 (permalink)
Originally Posted by rmay635703 View Post
He has an AT power supply...
Oops! *retreats to the far corner*
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 66 03-28-2012 08:06 AM
Why We Have No Wind or Solar Power SuperTrooper General Efficiency Discussion 220 07-20-2011 10:37 PM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
Power Supply Efficiency trebuchet03 Saving@Home 18 02-08-2009 02:57 AM
