12-17-2008, 12:41 AM
#11 (permalink)
hey. coincidentally, i dove back into the psu realm to get a new one.I ended up eith an earthwatts 380w. The twin hard drives have no more wah wah stray noise, it is nice.
I learned that "active pfc" is real, and I am enjoying my pc.PSU is a sensitive subject, I got electrocuted by a popular brand computer to the point of knocked out and exploding/chipping teeth for years afterwards. (claimed not be possible).
back to the future:
I do large functions on home made scripts (if to ponder 3400mhz at 100%, 167F degrees and ram floating full at 3gb for 24 hours or so) and the pc stays normal. Still screaming when it comes down, but the fan in psu winds up (like it knows it now).Active pfc is attributed to this, I have never had a psu that knew to wind up after the work is done to take away excess invisible..
passive pfc is done in my pc world. If to go for apfc psu, do get a late revsion, there is a year of sheisters in that too...(like all electronics) late 2007 and later is a good bet.
I could advice to look for the 2 (or more) 12v rails to be exactly the same output...that is all I learned and it worked.
speaking of silent pc review it is a favorite place, and I did write up about active pfc in a thread there with a simple analogy about how the volts go into non-efficient (written by the gov't, and i cut and pasted quotes)
browse around there is some smarter than I there to really answer questions.
12-17-2008, 01:40 AM
#12 (permalink)
Moderate your Moderation.
Easiest way to build a green PC - Low power monitor, and conservative on the specs. Your daily use PC doesn't need to be a gaming machine with 500GB of HDD space. IF it does, you need to delete some of your pr0n.
OS tuneups are necessary, so get ready to work with software if you're not familiar already. Yes, Windows DOES become completely stupid after about 3 months of regular use. It happens, get over it and learn to fix it.
Keep programs that you use frequently loaded in memory on startup, lose everything else. This will allow you more room in memory before your computer needs to start using Pagefile (Virtual memory) to save things. virtual memory is a cell on your HDD that means your computer will wildly spin up your HDD randomly for a single data bit of memory that it takes ~400ms to find.
Don't use an 800w PSU if you don't need it. Overdoing it here can actually cost you a bit, as the capacitors and resistors and other components are more plentiful in a larger capacity PSU. They turn electricity into heat, moreso, the more of them there are.
These are just a few tips to help.
I actually use a 90W PSU in my old system, and I run 2 80GB IDE HDD's with a 700mHZ Athlon (card-style CPU, socket A) and 768mB ram. It runs XP, with a few tweaks to make it do it's job better, and more efficiently. It's actually faster than my old Vista retail PC at most daily functions.
Of course, you can save power by upgrading your internet connection too... the faster you browse, the less time you need to spend in front of your computer.
12-17-2008, 08:27 AM
#13 (permalink)
I just picked out my components (not ordered quite yet) for my new power efficient office/gaming system. It incorperates Nvidia's hybrid SLI technology to allow very low 2d operating power consumption while still having great 3d gaming performance. Basically, when in 2d mode it uses the onboard video GPU and powers down the video card. When you need to do 3d, it powers on your PCI-e video card (that would otherwise be guzzling down 40-60W all the time) and you get it's benefits. Great idea. This setup will allow my machine to idle well under 100W in 2d mode, yet still allow me to play anything I want game wise. I also went with an 85% efficient PSU and power efficient 45W AMD processor to keep power consumption down.
12-17-2008, 12:14 PM
#14 (permalink)
That's sounds like a great combo of power and efficiency there! Hope it works out for you.
12-24-2008, 09:16 AM
#15 (permalink)
I never thought of a 45W processor as being particularly efficient, especially when backing off the processing power a small amount yields disproportionately large dividends on the electrical side... but that may just be me.
Also on this subject... A PSU is a fairly simple device compared to the computer it runs, and almost all pre-built are built using bottom-of-the-barrel components... Has anyone attempted to build a PSU from raw components before?
I build guitar amps from scratch...
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
12-24-2008, 09:21 AM
#16 (permalink)
I don't think HD space has much to do with it, so much as the NUMBER of drives. I run 3, 1 internal 2 external, and they don't consume a lot of power really. Maybe 20W combined under load? Then again they aren't super-fast drives. I think they're 5400 and 7200 RPM drives. I've got about 830gb of disk space now, and I would reduce my energy consumption right now by replacing my 250 and 500 external drives with a single-disk 1tb unit.
And I figured out a way around Windows breakdowns... Ditch the Windows. All manners of Linux out there, that are actually getting quite user friendly now, and people still use Windows? Bah.
12-25-2008, 03:18 PM
#17 (permalink)
I agree. The 45W Athlon X2 5050e is what I bought. Its the lowest wattage chip for its speed currently avaliable AFAIK. I'll be combining AMD's cool'n quiet technology with crystalcpuid to lower power consumption even more.
02-07-2009, 07:49 PM
#18 (permalink)
When building my latest rig, I went for low power use. I had considered replacing the now 5 year old 300W Enermax supply with something more efficient, but I'm now glad that I did not. The cost benefit to going with an 80-Plus certified unit simply would not have been there with the dual core Atom based board I am using now. At full steam including the LCD monitor, it doesn't even break 90W of consumption on the Kill-a-watt, whereas the old AthlonXP that it replaced idled at about 125W and peaked around 200.
I know that my monitor draws about 15W on it's own, so 75W of consumption from a system that normally draws at least 65W out of the most efficient configuration is not bad since it's only on when I actually use it. So at best, a super-efficient PSU might save me 5W.
I would certainly demand over 80% efficiency out of any future supply that I buy, but older lower power supplies really aren't bad enough to warrant the upgrade when you start counting the pennies to do it.
02-08-2009, 02:57 AM
#19 (permalink)
aero guerrilla
Here's a tip for Linux users (and anyone willing try Linux):
Install a new version with kernel at least 2.6.22 and install PowerTOP. Since 2.6.21 the kernels are tickless, while PowerTOP is a tool for seeing which processes are causing the CPU to wake-up out of more efficient states. It also gives advice about what to change and how. PowerTOP was supposed to be for extending battery life in laptops, but you can use it in desktops also. Plus, both Linux and PowerTOP are free
I've been on Linux for almost 10 years now (Fedora 9 on the destop, F6 on the laptop to be upgraded soon). I have a small partition with WinXP programs which weren't writen for Linux, though I could just use the Wine emulator.
Piwoslaw's Peugeot 307sw modding thread
