Old 11-03-2010, 02:40 AM   #1 (permalink)
Grrr :-)
Nerys's Avatar
Cherokee - '88 Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Grand Voyager SE
ppc/wm mpg software?
Any suggestions? I used to have this great program for my palm pilot that was very finger friendly I just tapped in my data and it logged it all for me.
I want to find similar software for my Pocket PC. Preferably freeware (would have to be truly great software for me to pay for an MPG logger :-)
I only found 2 free programs and the one does not log and the other is garbage (instant crashing every time won't even load now)
would be nice to have something that "auto files" some default into from you and you can finger friendly alter it slightly for accuracy and that did not require the popup or slide out keyboard to use.
Graphing would be nice but not required.
integration with ecomodder would be amazing but I guess thats a fairytale :-)
Old 11-07-2010, 09:20 PM   #2 (permalink)
Grrr :-)
Nerys's Avatar
does absolutely no one know of any ppc/windows mobile software for recording and calculating fuel economy?
Old 11-08-2010, 11:12 AM   #3 (permalink)
Aveo - '08 Aveo LS
palm no longer exists as a company, and the palm pilot is ancient history...
Try a notepad noting your odometer and fuel fillup
Old 11-08-2010, 11:33 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Mpg.java
you can try the java soundcard mpg thingie, does the ppc have stereo inputs?
Code:
import java.awt.Color;
import java.awt.Container;
import java.awt.GridLayout;
import java.awt.event.ActionEvent;
import java.awt.event.ActionListener;
import java.awt.event.WindowAdapter;
import java.awt.event.WindowEvent;
import java.io.File;
import java.io.FileInputStream;
import java.io.FileOutputStream;
import java.text.NumberFormat;
import java.util.Properties;
import javax.sound.sampled.AudioFileFormat;
import javax.sound.sampled.AudioFormat;
import javax.sound.sampled.AudioInputStream;
import javax.sound.sampled.AudioSystem;
import javax.sound.sampled.DataLine;
import javax.sound.sampled.TargetDataLine;
import javax.swing.BorderFactory;
import javax.swing.JButton;
import javax.swing.JFrame;
import javax.swing.JLabel;
import javax.swing.JPanel;
public class Mpg extends Thread {
	static String propFile = "./mpg.properties";	// place to persist confguration and trips.
												//Will be created on first run if it doesnt exist.
	static int injThreshold = Integer
			.parseInt(getProperty("injThreshold", "-30")); // value above the noise
	static int vssThreshold = Integer
			.parseInt(getProperty("vssThreshold", "100")); // value above the noise
	static double distanceFudge = Double.parseDouble(getProperty("distanceFudge", "3200.0"));
	static double fuelFudge = Double.parseDouble(getProperty("fuelFudge",	"8000000.00"));
	static String dummyFile = getProperty("dummyFile", "");
	// low level stats tracked in the "trip" class.
	class Trip {
		String name;
		long sampleCount; // num samples, used to compute elapsed time, good
							// for about 58 billion hours @ 44100hz
		long injHi; // stores number of samples that were "HI" (injector was
					// open)
		long vssTot; // how many pulses from the vss, indication of distance
						// travelled
		public Trip(String _name) {
			name = _name;
		// real lightweight update process, gets called at end of audio chunk
		public void Update(long _sampleCount, long _injHi, long _vssTot) {
			sampleCount += _sampleCount;
			injHi += _injHi;
			vssTot += _vssTot;
		public String toString() {
			return "name=" + name + ";sampleCount=" + sampleCount + ";injHi="
					+ injHi + ";vssTot=" + vssTot;
		public void reset() {
			sampleCount = 0;
			injHi = 0;
			vssTot = 0;
		public Trip load() {
			sampleCount = Long
					.parseLong(getProperty(name + ".sampleCount", "0"));
			injHi = Long.parseLong(getProperty(name + ".injHi", "0"));
			vssTot = Long.parseLong(getProperty(name + ".vssTot", "0"));
			return this;
		public void save() {
			properties.put(name + ".sampleCount", "" + sampleCount);
			properties.put(name + ".injHi", "" + injHi);
			properties.put(name + ".vssTot", "" + vssTot);
		public double miles() {
			return (double) vssTot / distanceFudge;
		public double hours() {
			return ((double) sampleCount) / (44100.0D * 3600.0D);
		public double gallons() {
			return (double) injHi / fuelFudge;
		public double mpg() {
			return gallons() > 0.0D ? (miles() / gallons())
					: Double.POSITIVE_INFINITY;
	class TripPanel extends JPanel {
		Trip trip = null;
		JLabel name = new JLabel("name");
		JLabel miles = new JLabel("miles");
		JLabel gallons = new JLabel("gallons");
		JLabel mpg = new JLabel("mpg");
		JLabel hours = new JLabel("gallons");
		JLabel mph = new JLabel("mph");
		JButton reset = new JButton("reset");
		/** used for limiting numbers to 4 decimal places*/
		NumberFormat fm = NumberFormat.getNumberInstance();
		public TripPanel(Trip _trip) {
			trip = _trip;
			setLayout(new GridLayout(1, 8));
			setBorder(BorderFactory.createLineBorder(Color.BLACK));
			add(name);
			add(miles);
			add(gallons);
			add(mpg);
			add(hours);
			add(mph);
			add(reset);
			reset.addActionListener(new ActionListener() {
				public void actionPerformed(ActionEvent e) {
					trip.reset();
			fm.setMaximumFractionDigits(4);
		public void upDateLabels() {
			name.setText(" " + trip.name);
			miles.setText(fm.format(trip.miles()));
			gallons.setText(fm.format(trip.gallons()));
			mpg.setText(fm.format(trip.mpg()));
			hours.setText(fm.format(trip.hours()));
			mph.setText(fm.format(trip.miles() / trip.hours()));
	private TargetDataLine m_line;
	protected boolean m_bRecording = true;
	Trip instant = new Trip("instant");
	TripPanel instantPanel = new TripPanel(instant);
	Trip current = new Trip("current");
	TripPanel currentPanel = new TripPanel(current);
	Trip tank = new Trip("tank").load();
	TripPanel tankPanel = new TripPanel(tank);
	public Mpg(TargetDataLine line, AudioFileFormat.Type targetType) {
		m_line = line;
		new Thread(new Runnable() {// thread to update the view every second
					public void run() {
						while (m_bRecording) {
							instantPanel.upDateLabels();
							instant.reset();// reset the instant trip after
											// displaying it
							currentPanel.upDateLabels();
							tankPanel.upDateLabels();
							try {
								Thread.sleep(1000);
							} catch (Exception e) {
				}).start();
	public void start() {
		m_line.start();
		super.start();
	public void stopRecording() {
		m_line.stop();
		m_line.close();
		m_bRecording = false;
		System.out.println(" inj sampleCount = " + current.sampleCount
				+ " inj hi = " + current.injHi + " inj vssTot = "
				+ current.vssTot);
	boolean ig = true;
	boolean vg = true;
	void processChunk(byte[] b, int c) {
		long ih = 0;
		long vt = 0;
		for (int x = 0; x < c; x += 2) {
			int val = ((int) b[x] & 255) - 127;
			if (val > vssThreshold && vg) {
				vt++;
				System.out.println(" vss going hi "
						+ (current.sampleCount + (x / 2)));
				vg = false;
			if (val < 0) {
				vg = true;
			val = ((int) b[x + 1] & 255) - 127;
			if (val < injThreshold) {
				ig = true;
			if (val > 0)
				ig = false;
			if (ig)
				ih++;
		instant.Update(c / 2, ih, vt);
		current.Update(c / 2, ih, vt);
		tank.Update(c / 2, ih, vt);
	public void realrun() {
		byte[] buffer = new byte[m_line.getBufferSize()];
			int c = m_line.read(buffer, 0, m_line.available());
			if (c != 0) {
				processChunk(buffer, c);
	public void run() {
		if ("".equals(dummyFile))
			realrun();
		else
			dummyrun();
	public void dummyrun() {
		try {
			String strFilename = dummyFile;
			File soundFile = new File(strFilename);
			AudioInputStream audioInputStream = null;
			audioInputStream = AudioSystem.getAudioInputStream(soundFile);
			int nBytesRead = 0;
			byte[] abData = new byte[44100];
			while (nBytesRead != -1) {
				nBytesRead = audioInputStream.read(abData, 0, abData.length);
				if (nBytesRead >= 0) {
					processChunk(abData, nBytesRead);
				try {
					Thread.sleep(1000);
			e.printStackTrace();
	public static void main(String[] args) throws Exception {
		AudioFormat audioFormat = new AudioFormat(
				AudioFormat.Encoding.PCM_SIGNED, 44100.0F, 8, 2, 2, 44100.0F,
				false);
		DataLine.Info info = new DataLine.Info(TargetDataLine.class,
				audioFormat);
		TargetDataLine targetDataLine = null;
		targetDataLine = (TargetDataLine) AudioSystem.getLine(info);
		targetDataLine.open(audioFormat);
		AudioFileFormat.Type targetType = AudioFileFormat.Type.WAVE;
		final Mpg recorder = new Mpg(targetDataLine, targetType);
		JFrame j = new JFrame("MPG Monitor!!!");
		j.setSize(640, 125);
		Container c = j.getContentPane();
		c.setLayout(new GridLayout(4, 1));
		JPanel hd = new JPanel();
		hd.setLayout(new GridLayout(1, 8));
		hd.add(new JLabel(""));
		hd.add(new JLabel("MILES"));
		hd.add(new JLabel("GAL"));
		hd.add(new JLabel("MPG"));
		hd.add(new JLabel("HRS"));
		hd.add(new JLabel("MPH"));
		c.add(hd);
		c.add(recorder.instantPanel);
		c.add(recorder.currentPanel);
		c.add(recorder.tankPanel);
		j.addWindowListener(new WindowAdapter() {
			public void windowClosing(WindowEvent e) {
				recorder.stopRecording();
				recorder.tank.save();//this just adds the trip fields to the properties object
				try {
					properties.store(new FileOutputStream(new File(propFile)),"");
				} catch (Exception f) {
				System.exit(0);
		j.setVisible(true);
		recorder.start();
	static Properties properties;
	static String getProperty(String tag, String dflt) {
		String s = "";
		try {
			if (properties == null) {
				properties = new Properties();
				try {
					properties.load(new FileInputStream(new File(propFile)));
			s = properties.getProperty(tag);
			if (s == null) {
				s = dflt;
				properties.put(tag, s);// will propogate default values to the
										// file
		return s;
Old 11-11-2010, 10:09 PM   #5 (permalink)
Grrr :-)
Nerys's Avatar
angelus I am talking about windows mobile - decidedly NOT a dead platform far from it.
I mentioned palm because when I used my palm I had great little programs for doing this. now the only program I can find crashes when I try to run it another is pay software and looks less impressive and the third only gives you one at a time data. No logging or anything like that.
dcb what in the world is that and how do I use it?
sadly no line inputs.
Old 11-12-2010, 06:48 PM   #6 (permalink)
Fuel Logger
Hope this help you.
SciLor's Fuel Blaster
Old 11-12-2010, 06:55 PM   #7 (permalink)
Grrr :-)
Nerys's Avatar
yeahhhh thats the ONE program I found and it simply won't run. It installed and loads one time then it refuses to ever load again. I tap the icon and it simply crashes without even showing anything on the screen.
I will try it again see what happens :-)
Old 11-12-2010, 10:25 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
That is a java program that monitors the injector and speed signals via a stereo sound card and computes mpg type stuff.
I have an axim and I *think* the earphone jack doubles as a line in jack, unfortunately I don't feel like messing with it.
Old 02-02-2011, 05:35 PM   #9 (permalink)
Yep, gettin' started...
ECONORAM - '07 RAM 1500 QC SLT flex-fuel
90 day: 17.82 mpg (US)
the Avenger - '08 Avenger SXT
Last 3: 27.18 mpg (US)
Send a message via Yahoo to ECONORAM
I found a program the other day that at least is WM6 compatible...OBDMobile. It is on Windows Marketplace. Link: RKlenka - View topic - OBDMobile is on Windows Mobile Marketplace! OBDGauge did install on my Tilt OBD Gauge , but I do not have a serial cable for it. I also looked at OBDPro and their adapters OBDPros , as well as BLueOBD blueOBD - bluetooth project based on OBD-2 , OBDKey OBDKey :: Wired and Wireless Automotive (OBD) Scan Tools ...but most of those require some dollars.
Are you looking for something to interact with the vehicle, or just something to log data into? How about tweaking an MS Excel spreadsheet?
Here are a couple other sites I've visited:
WinODB - Ordinateur de bord pour Windows Mobile
OBD-2 Vehicle Explorer Scan Tool Browser
OBD Diagnostics, Inc. - Diagnostic Software lots of stuff here...
Old 02-02-2011, 08:25 PM   #10 (permalink)
Grrr :-)
Nerys's Avatar
I am amazed at how little basic simple auto programs their are. ODB is only good if you have both 1996 or newer and a serial cable :-)
I never had trouble finding palm software. strange.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
free OBD2 software with MPG calc whitewiz Instrumentation 6 02-18-2012 11:31 AM
SGII first observations! Old Tele man Success Stories 10 04-02-2010 01:26 AM
SpeedTracer MPG graphing software and ... mwebb EcoModding Central 0 10-01-2009 10:50 PM
