Old 07-05-2011, 06:09 PM   #1 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
Alternator modifications
I found a paper on improving alternator efficiency. With out a whole lot of work one could bump there car alternator efficiency by 4%.
http://itee.uq.edu.au/~aupec/aupec04.../PaperID82.pdf
The Following User Says Thank You to ConnClark For This Useful Post:
Cd (07-28-2011)
Old 07-05-2011, 08:34 PM   #2 (permalink)
DieselMiser
ConnClark's Avatar
I'm also wondering about replacing the diodes in the alternator with ones that have a lower voltage drop.
Old 07-06-2011, 03:41 AM   #3 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Downloaded for reading. Looks interesting.
Old 07-08-2011, 02:46 PM   #4 (permalink)
Black Beauty - '09 Honda Accord EX-L
90 day: 27.44 mpg (US)
Save time; Disconnect Alternator And Run On Battery
Some of you may remember me, I have always been a supporter of the idea of just disconnecting your alternator to increase MPG.
I did this on:
2004 4.7L Dodge Dakota
2004 Jeep TJ
2009 Honda Accord
I had no problems and was able to drive 75 miles before reaching 12.1 volts on the stock battery.
Today, I have a Group 24 Gel Cel in the trunk of my Honda and a quick alternator disconnect that can be used to turn off the alternator and go for about 50 miles in the summer heat without any worries.
Old 07-08-2011, 03:23 PM   #5 (permalink)
...or you could slow down by 1 MPH and probably get just as much benefit!
Old 07-08-2011, 03:39 PM   #6 (permalink)
The PRC.
Hyundai i10 "Blue" model in the UK has an "Alternator Management System" which seems to monitor when the engine is under load (e.g. climbing hills, accelerating hard) and reduces the demand from the Alternator from the engine. It also increases it when it can such as in gear downhill coasting etc.
Linky
Here is a pic from the brochure
The "Blue" (named after the VW/Merc "Blue" eco technology - well they don't want to give the Green Party any credit do they ?) failed for me because it's too expensive for what it is.
Old 07-08-2011, 05:21 PM   #7 (permalink)
1995 Previa LE S/C Driver
The engine being under higher load can demand more from the electrical system -- but I could be thinking in terms of points and condensor ignition. Changes in voltage can result in a weaker spark, which is the last thing you'd want.
Another mod that could be worthwhile (for those of us who love our forced-air HVAC) would be to replace the blower motor with something more efficient, or to lighten the fan blade assembly to reduce the torque needed to turn it. Maybe even to add an ultra-low speed to the blower motor so the A/C can be run with minimum blower electrical load. Most A/C will not engage the compressor if the fan isn't running, so to have a fractional amperage fan setting, or even an override if you're in the "Fresh" mode so that the A/C will run with the fan off, can save some electrical demand.
Tie the fan speed automatically dropping under high engine load with the alternator cutting out under the same conditions, so that you're not burdening the battery so much up those hills, and downhill, the battery recharges just that much faster.
Old 07-08-2011, 06:03 PM   #8 (permalink)
What about one of those "flexable" solar panels on the roof to keep the battery charged?
Old 07-08-2011, 06:43 PM   #9 (permalink)
DieselMiser
ConnClark's Avatar
Another interesting paper showing typical losses for each part of the alternator as well as potential savings of improving alternator efficiency.
http://www.delcoremy.com/Documents/H...ite-Paper.aspx
In it they say that the two leading losses of efficiency of an alternator are the Ohmic loss of the wire and the diode voltage drop.
ECONORAM (05-15-2013)
Old 07-08-2011, 06:50 PM   #10 (permalink)
I did this on:
2004 Jeep TJ
2009 Honda Accord
On the Honda do you really gain much as Honda uses a 2 stage load alternator , ELD (runs at low outputs with low loads to increase mpg ) ?
