Old 04-19-2009, 08:01 PM   #51 (permalink)
Originally Posted by Otto View Post
Dave, from your website I notice that thought has been given to using Goldschmied pressure thrust to enhance a tractor propeller airplane, as the aft fuselage is sharply tapered, with annular inlet.
How best to use Goldschmied pressure thrust on a pusher configuration?
I know his pusher was designed to have natural laminar flow over most of the forward body and a split tail not unlike that of the P-38 Lightning, but I'm not sure which details would make the best use for a pusher design. I've heard some chatter suggesting a piston-pusher delta wing design might work well (!?).
As you mentioned, I spend a lot of time thinking of how to put this on a current aircraft like the Cirrus SR22 or Diamond singles, which are pretty good candidates as far as current piston singles go.
-Dave B
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Tire pressure (of winter tires) tasdrouille General Efficiency Discussion 20 08-12-2009 01:38 AM
Relative tire pressure? bwilson4web EcoModding Central 4 03-16-2009 10:35 PM
