Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-23-2008, 10:51 AM   #11 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
hmmm using well water may be a idea , just return the water to the well.. any one heard of doing this at all?
Old 07-23-2008, 10:56 AM   #12 (permalink)
Veggiedynamics
little googling gave me this...
Cheap: How to Get Free Air Conditioning From Your Water System
Old 07-24-2008, 02:34 AM   #13 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.18 mpg (US)
that is interesting....
what part of wv u from?
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 07-24-2008, 08:44 AM   #14 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
diverting water before it goes to the hot water tank, toilet, etc is a good idea. Basically any place that does not require COLD water could have its supply diverted to a rad first. The kitchen tap is the only place that I can think of that i'd use COLD water from without turning on the hot tap a little.
Old 07-29-2008, 06:26 AM   #15 (permalink)
1997 Civic POS - '97 Civic EX
90 day: 33.29 mpg (US)
Send a message via AIM to ajax_6531 Send a message via Yahoo to ajax_6531
How about a weave of large diameter tubing spread throughout your yard underground? As the water flows, the greater surface area of contact between the tubing and the outside would be more efficient in heat transfer. You can use whatever you want without the worry of freezing as long as it's buried below the frost line. Be sure to insulate anything above the frost line and in the air.
IYAOYAS
Old 08-10-2008, 10:34 AM   #16 (permalink)
Civic - '98 Civic DX
90 day: 41.44 mpg (US)
Originally Posted by Coyote X View Post
But I did manage to find a potentially endless supply of 55 gallon barrels for free
If that is the case...get them all...use what you need to experiment on your system...then take the rest of the endless supply to a metal recycler...and make some extra money.
In omaha scrap metal is selling for about 190 a ton.
Old 08-14-2008, 10:12 PM   #17 (permalink)
I'd be worried about the tank leaking -- how about a boatload of tubing in layers in a long skinny trench?
How can you incorporate a cheap windmill and solar reflector into this?
Old 08-14-2008, 11:26 PM   #18 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
We don't get wind here I think the record for the town is 50mph wind. Normally the wind is maybe 1-2mph at best and before a storm we might get 5-10mph wind.
I don't really have a plan for when a barrel gets old enough to leak but I figure I can get an easy 5-10 years out of them if I make sure they are coated well with undercoating or something else similar.
But before I can do any of it I have to get caught up on all the other random work that needs done around here. Really I probably won't get started trying this out till spring.
My Convertible Metro XFI Plug in Hybrid Project build log
What is the best cheap car for Hypermiling? roadracer380 EcoModding Central 4 06-12-2010 01:50 AM
Good cheap project cars ebacherville Aerodynamics 13 05-08-2008 12:04 PM
Saving a few watts - a few ideas that I use around the house Lazarus Saving@Home 10 02-01-2008 07:13 PM
