Old 05-04-2011, 09:23 PM   #1 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
Prius EV mode top speed?
Just wondering... what are the top speeds of a 2004 and 2010 Prius in EV mode?
My 8mi commute tops out at 54mph, and I'm curious about whether a Prius with a large LiFePO4 battery in place of the stock one could do the job without firing up the ICE in good weather.
I see that the 2012 Prius PHV will top out around 60mph in EV mode, and the 2004 is rated for 41mph, but I wonder if both could be made to go faster.
Old 05-04-2011, 09:37 PM   #2 (permalink)
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
After warm-up:
  • 41 mph - NHW11 (01-03)
  • 41 mph - NHW20 (04-09)
  • 46 mph - ZVW30 (10-current)
However, there is a small window during the first 45 seconds in the NHW11 and more than 45 seconds in the ZVW30 where the engine runs but motive power is drawn from the traction battery. Very strange window.
My understanding is one of PHEV kits for the NHW20 gets up to 52 mph in EV mode but I don't know the details.
Bob Wilson
Local record
Old 05-04-2011, 09:46 PM   #3 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I think calcars modified their prius to allow higher speeds by telling the car it was out of gas. Not sure how exactly they do this.
With the EV mode button, you can only go up to 35 mph.
Old 05-04-2011, 10:56 PM   #4 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Kill the fuel pump. That said I've read that above ~40+mph is too fast for MG2 if the engine isn't idling.
Old 05-05-2011, 09:25 AM   #5 (permalink)
CM400E - '81 CM400E
I have also heard that. Due to the nature of the planetary setup, 40+ mph spins MG2 up to ~10k rpm I think. Its moving pretty good. I'm not sure how they're getting around this with the PHEV prius which can go up to 62 mph in EV mode. I guess different gearing?
Old 05-05-2011, 04:35 PM   #6 (permalink)
101% win
roflwaffle's Avatar
Toy - '82 Pickup
Yeah, the new one has different gearing IIRC. From what I saw on the yourube videos they just let the engine idle for older plug-in kits. It'll kick on periodically to make sure the cat is functional, but if the SOC is high enough it'll use the electric motor for the most part AFAIK.
Old 05-05-2011, 05:48 PM   #7 (permalink)
Left Lane Ecodriver
Well, that's a little disappointing. I already have an electricity-guzzler that can do EV mode by shutting off the fuel injectors and fruitlessly spinning the engine.
Originally Posted by Ewert Energy
The new Hybrid Energy Manager from Ewert Energy Systems allows for 70MPH electric-only mode and seamless transition back to gasoline powered drive in a converted Prius. This feature is available with the 20 Mile plugin hybrid conversion kit from Plug-In Home.
The Hybrid Energy Manager takes full advantage of both MG1 and MG2 motors and does (at certain speeds) spin the ICE without injecting any fuel to prevent damaging the motors. MG1 and MG2 operate within the technical specifications during full electric drive.
So I could beef up the battery on a Prius, but there isn't a good way to get rid of the constant, ~4kW drain from engine friction above the speeds listed in post two.
Back to the old drawing board... I will resume dreaming about dropping a one cylinder diesel in an EV-converted Insight.
