Old 11-21-2009, 08:21 PM   #11 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
I don't know for sure, but it looks like that cover actually covers down to the widest section of the tire's sidewall, meaning that would be a "normal" sized wheel, and part of the tire is covered. This is entirely possible, because at speed, the amount of air that could get behind the wheel cover wouldn't even be a breath to the average human. You'd want to keep your tires fully inflated, though, or risk damage to the (very expensive) covers.
"ソʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 11-21-2009, 08:25 PM   #12 (permalink)
Pok駑oderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Rokeby -
Originally Posted by Rokeby View Post
CarloSW2,
OK, I can see that as an alternate explanation for the Moon Craft arrangement.
Of course, you can't really tell whether the center part, the "donut hole"
comes off first, or the cover, I guess that's the "donut," does. Maybe you
just push on the "hole," and the "donut" comes off.
Yeah, that would be fantastic because that solution would be "easy-off" and road worthy.
It seems like the air valve access hole is somewhat larger than necessary to
get an air hose pressed on. Maybe it needs to be that big to get your fingers
around the valve cap.
That's egg-zactly right. If you can't get a good hold on them, the valve caps can fall behind the wheel cover. On my cheesy wheel covers, my access hole is too small. To solve this problem I made a "magnetic" valve cap using a valve cap with a "nut shape", so it can be removed with a 3/8 socket. The socket is metal and the valve cap is magnetized, so it stays in the socket after I unscrew it.
It's too bad that there isn't more info readily available on these covers.
They have only appeared on a few cars.
I would really, really like to know more about them... $$$
I agree. I want to see INSTALLATION instructions. That would answer all of our questions.
CarloSW2
American Solar Energy Society
Old 11-22-2009, 12:37 AM   #13 (permalink)
Wanderer
Sorrow Six Star's Avatar
Winona - '86 XT DL
Spoon S2000 Mooncraft Dry Hard Top - JHPUSA
^^ S2K aero top by moon craft
ムーンクラフト【MOONCRAFT】オフィシャルサイト
apparently they own and rent a wind tunnel....
(maybe we should find a wind tunnel to rent in the states?)
Aero Prius lunarhighway Aerodynamics 21 10-08-2011 03:29 PM
Prius aero mods (undertrays, grille block, mirror delete...) krousdb Hybrids 42 06-05-2011 02:27 PM
PBS takes the Hummer v Prius bait SVOboy Hybrids 51 05-19-2010 12:35 PM
Aero prius bodykit JMags Aerodynamics 25 02-28-2009 10:06 PM
Kit for aero modding Prius Cd Aerodynamics 10 03-17-2008 05:59 PM
