Old 07-23-2008, 01:53 PM   #1 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '010 Prius Black
90 day: 56.78 mpg (US)
Prius Question
I'm posting this for a friend of mine that owns a prius and he has a question about pulse and glide with the prius.
His question was is there any benefit to neutral coasting (vs. just coasting in drive) with a prius since he assumes fuel is not being used when the car is coasting in drive after pulsing the pedal and releasing the pedal. Because the prius switches to battery power when releasing the gas pedal is there any benefit to pulse and glide with the prius?
I'm really not up to speed on how the prius works but I told him my fellow ecomodder's would defiantly have an answer...thanks!
Old 07-23-2008, 02:00 PM   #2 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
I found neutral gliding helpful when the engine was cold.
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-23-2008, 02:03 PM   #3 (permalink)
neutral gliding in a prius or your civic? Just to clarify...specific to the prius because it used gas and battery powered engines...is neutral coasting beneficial vs. in-drive coasting?
Old 07-23-2008, 02:08 PM   #4 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
I am by far not an expert in Prius Drivetrain, but I would think that it may not matter with a prius because the Prius should disengage the tranny when coasting, since it was designed for that. The only thing that would slow down a prius during a coast is the regenerative braking, IMO. By switching into neutral you may by pass that system, which would be beneficial, but you would also eliminate the regen braking which may not be so good.
This of course is all theoretical ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 07-23-2008, 02:10 PM   #5 (permalink)
Vince-HX's Avatar
EJ7 - '96 civic Hx
In a prius. I found that the engine tries to warm up and runs quite a bit more then it needs to so I would put it in neutral to glide so there weren't any arrows on the screen. Pulse and glide is deff worth it in a Prius but the point is to accel and glide without any arrows, not worth it imo to try and use all electric assist all the time.
There are quite a few good guides online on proper pulse and glide techniques specifically for Prius's.
Driving the Prius normally = 55mpg, pulse and glide = 75 average
www.full-race.com
Old 07-23-2008, 02:15 PM   #6 (permalink)
My guess was that pulse and glide in a prius is not "AS" beneficial as in a normal engine only vehicle since the engine is essentially shutting off after depressing the brake pedal and switching to battery power anyway.
I use P&G in my 4runner and obviously the benefits greatly impact my mpg but I'll have to do some more reading on the prius to see what benefits, if any, there are for doing it in the prius.
Please keep the responses coming as I'm trying to help a friend with this thread! Thanks!
Old 07-23-2008, 02:19 PM   #7 (permalink)
The benefits would be amplified with the prius.... Even though you are using the electric motor most of the time in the city, by P&G, you use less power from the battery, therefore extending the range, thereby using the gas engine even less ...
So if there are area to explore Prius P&G, visit them, squeeze every drop out of that puppy. Nothing pisses me off more than watching a Prius blow my doors off @ 80mph on the hwy ....
Old 07-23-2008, 02:35 PM   #8 (permalink)
Good point Trik!
My friend is at about 52mpg right now but uses no P&G...he does drive cautiously and rarely revs the engine (and never abuses the gas pedal). I know he'll never do an aero mod but he does plan to inflate tires to near-max psi soon. I'm guessing with high psi and more attention paid to P&G, slow gas pedal, etc. he would be around 60mpg.
Old 07-23-2008, 03:14 PM   #9 (permalink)
Ecomodding Amateur
krousdb's Avatar
Cold Fusion - '04 Prius
90 day: 67.34 mpg (US)
There is actually a benefit with neutral coasting because there is no power transfer to or from the battery. Any power transfer results in a loss due to conversion efficiency. Just remember that when in neutral, you will get no regeneration when you brake. Pop it back in drive before braking to get the regen.
For more info on P&G, see my comments at the link below:
Toyota.com : Hybrid Synergy View : 2005 : Fall : Prius Marathoners Top 100 mpg
Old 07-24-2008, 08:13 AM   #10 (permalink)
Thanks for the great info Kraus! Interesting reading even though I don't own a prius...will be a great help for my friend. Would love to see him pull 65+ mpg with no major aero mods other than psi and P&G.
Prius aero mods (undertrays, grille block, mirror delete...) krousdb Hybrids 42 06-05-2011 02:27 PM
Help me convince GF to pay $150 more to rent a Prius brickinthewind Hypermiling / EcoDriver's Ed 8 07-18-2008 02:44 PM
Prius wake turbulence Otto Aerodynamics 13 04-21-2008 11:44 AM
Autoblog Prius review: more evidence of the power of MPG instrumentation MetroMPG Instrumentation 6 01-02-2008 11:48 PM
Bullfrog Power wind farm owner dumps his Insight for a Prius MetroMPG General Efficiency Discussion 0 12-16-2007 11:50 PM
