Old 12-05-2010, 02:29 PM   #1 (permalink)
bryn's Avatar
sputnik - '93 silhouette
90 day: 23.23 mpg (US)
home sweet home - '92 clubwagon E-350 xlt
very excelant - '92 civic vx
problems with lean burn in my civic vx
i just bought a 92 civic vx a week ago, working out the kinks.
it feels like when it should be going into lean burn, warmed up, at cruising speed, light throttle, it stumbles or misses as if it was running out of gas. if i give it just a little more throttle say from 20% up to 25% runs fine again.
also if i am driving down a hill in gear, where i think it should cut fuel to the injectors the check engine light comes on until the car is turned off again.
any vx owners had either of these problems? or know how to check the check engine light code?
thanks much for any ideas
Old 12-05-2010, 02:45 PM   #2 (permalink)
tim3058's Avatar
Project-Civic MPG - '93 Civic DX/VX swap
90 day: 47.04 mpg (US)
Silverado - '07 Silverado 1500 LT
90 day: 14.52 mpg (US)
Civic II - '07 Civic EX
90 day: 31.4 mpg (US)
Silver Bullet - '86 Camaro Z28
90 day: 19.74 mpg (US)
My lean-burn issues seemed to be traced back to faulty (re-)wiring by the previous owner, although the code said O2, along with a few others. You can use a wire to jumper across the 2 prongs in the green terminal hanging under dash by the pass. door to see what the codes are.
Check your connections under the hood along the right pass. fender. Maybe plug & unplug each one a few times to clean up terminals. Then check the wires leading to the ECU by the pass. door pillar (under the dash) for any ghetto re-wiring.
Old 12-05-2010, 03:18 PM   #3 (permalink)
bryn's Avatar
thanks i will check out the wiring before i start spending money.
Old 12-05-2010, 06:12 PM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I got a great deal on my civic vx for the same issues and I bought it because I was 99% sure that it was the o2 sensor, replaced the o2 sensor and it runs perfectly.
The o2 sensor does not always trips the check engine light when it is first wearing out but it sounds like yours is pretty far gone.
It will be a bit pricy but if you search around you can find them for $100 or so, otherwise auto part stores sell them for $300.
The Following User Says Thank You to Ryland For This Useful Post:
bryn (12-06-2010)
Old 12-05-2010, 08:57 PM   #5 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
And congrats on finding a VX, bryn. Envious.
Old 03-10-2011, 07:17 PM   #6 (permalink)
Mighty Mouse - '93 Civic VX
90 day: 43.3 mpg (US)
Tank - '03 G35 premium
90 day: 22.24 mpg (US)
Did you figure out what the problem was? I'm having the same issue. Unfortunately for me it's not the 02...
Old 03-10-2011, 07:36 PM   #7 (permalink)
Ryland's Avatar
It could also be the throttle position sensor on the throttle body.
Old 03-14-2011, 07:16 PM   #8 (permalink)
It's not the TPS, MAP or the EGR, car has new NGK plugs, OEM cap/rotor, plug wires, fuel filter... Strangely the problem goes away when i unplug the 02 but it's a brand new NTK L1H1 sensor.
I've cleaned the EGR ports and valve, seafoamed the engine...
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
civic vx 02 sensor UPDATE and lean burn monitor ? coletrain777 EcoModding Central 16 01-04-2012 02:50 PM
lean burn rules~! coolwHip Introductions 42 10-01-2011 05:42 AM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Civic VX lean burn ivicR DIY / How-to 43 10-22-2009 01:40 AM
