Problems with Pulse and Glide.
Today I was out in the car, by myself, and traffic was extremely light. I tried Pulse and Glide, accelerating up to 60 mph, then knocking it out of gear until speed dropped to 35 mph before accelerating again. I found it very unsatisfactory because the speed bled off quicker than I was able to build it back up. To be fair, I accelerated in 5th gear (changing down to third would have put me in the 12 - 15 mpg category without a huge improvement in performance), but the real problem was the lack of inertia. I even thought I had a brake grabbing, but I jacked car up on my return and checked. The brakes were cold and the wheels spun freely. The problem seems to be a small, light, not particularly aerodynamic and under-powered car. It wasn't even windy and the road was dry and fairly flat. Don't know what to do.
P&G primarily helps when your vehicle's engine can provide much more power than is needed to push your car down the road. The pulse operates the engine at peak thermal efficiency, and the glide minimizes fuel usage when the power isn't needed. If you're already cruising at close to peak efficiency, then the results are much less. Also, at lower speeds you'll find P&G is more effective at increasing your fuel economy because the lower speed doesn't require as much power, thus your engine is oversized for that speed.
With your quite un-aerodynamic car and smaller engine, I bet you won't see huge gains from going to P&G. The only way to know for sure is to A-B-A test it. That should give you an idea of how much P&G is good for. |
Black Widow (Ford Festiva) | Fuelly |
I tried a whole tank of constant P&G with my car a few years ago. I saw no improvement in MPG. And that was with engine-off coasting. Edit: My 1,000th post on EcoModder! :D |
You could watch intake manifold vacuum. If you consistently run at 5 to 10 or 12 inches vacuum, you have nothing to gain by P&G. Focus on DWG and DWL. P&G benefits those who run at 15 inches or greater. |
3.5 - 4 psi. |
For those living less than about 1000 feet above sea level:
0 inches vacuum is about 14 PSI MAP 5 inches about 11.5 PSI 10 inches about 9 PSI 15 inches about 7 PSI 20 inches about 5 PSI So you are right in the range of "forget P&G", and use DWL and DWB. The exact conversion is 29.92 inches to 0 PSI at sea level, decreasing 1 inch per thousand feet. And 0 inches to 14.7 PSI. That's why I said "about" in the above table. |
Nothing happens in a vacuum.
P&G can help a ton, but you've got to work the terrain, traffic and car. Use downhills and times when you'd be slowing down anyway. Use a 5-10 mph window instead of the 25 mph window you're talking about- your pulses will be a lot shorter, and by using circumstances better your glides will be longer. Make sure they're appropriate for the gearbox, because as you've spotted, pulsing from 35 in 5th just isn't right. |
I always glide down hills and to a stop. I also glide into roundabouts, common hereabouts (there are seven on the 1.8 miles I drive to take my wife to work). DWL and DWB are my primary methods of getting the numbers up. I am now averaging
60 mpg (UK)/50 mpg (US) for the last 10 tankfuls (calculated). |
