Old 12-13-2012, 11:11 AM   #141 (permalink)
Well thats a great time to do mods look at all the money your saving in fuel right now
94 Geo Metro 52-56 MPG
06 Jetta TDI 46-48 MPG
Old 12-13-2012, 09:24 PM   #142 (permalink)
Rapturee
HHOTDI's Avatar
Sippy2 - '15 Honda NC700XD DCT
90 day: 59.51 mpg (US)
Shorty - '02 Ford F150 XL
Originally Posted by hotrodfeguy View Post
4.11's are the killer almost anything is better than that. I swapped from 3.25 to 2.75's in my 77 with a 351M and it was a lot better. I think by looking at your engine there you have a 351C or a 351M either way the MPG is in the rear gears right now. I would even leave the trans alone for now. Go with anything but the 4.11's good GOD mate !!!
Right on Sir...I too have had several of those older F-series pickups and that is definitely "NOT" a Windsor series motor. The first indicator is the placement and position of the Thermostat housing...dead-give-away that it is the 351C/351M/400M series motor. Second look-see is the corner of the head next to the valve cover, if there is an "M" stamped there it is generally a 351M/400M, if there is a "2" or "4" stamped there then it is usually the 351C. There are variants if someone swapped the heads out etc etc. More if needed.
Old 12-13-2012, 10:11 PM   #143 (permalink)
Rapturee
HHOTDI's Avatar
ooops! The nice part is now you can save all the faster for the required mods you need. May I humbly suggest the rearend gears first, then a nice 5speed trans as the more gears you have available to use will be much easier for you to haul the heavy loads you stated earlier that you haul 1-2 times weekly. I have had the granny low 4-speeds and the C6 3speed automatics. Both worked well and only ever got me 8-10mpg. Then i drove a friends F250 with a 5speed trans, wow that was nice for heavy pulling, way better for pulling/hauling those heavy loads and the 5th gear for the overdrive mileage! Great build and congrats to you and your business. I too had plenty of the 9" third members that you could've had for free, too bad you're down under mate, the shipping would kill'ya even with a free part! :{)
Old 12-13-2012, 10:16 PM   #144 (permalink)
Rapturee
HHOTDI's Avatar
Hey, lets throw you a curve...you could always dump that 351/400M series motor and do a Turbo Diesel swap. The Mercedes OM617 5cyl is an awesome swap as well as the 4BT Cummings. Dunno what you have available down under....but there are a lot of swaps like that here in the states that are netting excellent fuel mileage and great pulling/hauling power! just a thought..... I am looking to stuff one of the OM617T into a willy's jeep for wheelin' in. Our big Powerstroke Excursion has a all-time best of 18.2MPG on a long trip to the beautiful Oregon Coast. We got 750 miles to that tank! Whoo Hooo! Keep up the great work mate! :{)
Old 12-13-2012, 10:30 PM   #145 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
what do your used trucks cost, mabe you could import a cheap calif rust free truck with the bed filled with the upgrade parts you need and sell the truck for all costs. win win
Old 12-20-2012, 08:42 PM   #146 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
Thats actually high on my list of possibilities, now that im not driving it anymore i dont have to worry about getting it back together the next day so an engine swap is a possibility, either some kind of diesel (havnt looked what is available yet) or a late model fuel injected V8, with matching 5 or 6 speed gearbox
In other news my mileage has gone wayyyy up... depending how much i pedal i should be getting a minimum of 150mpg :P
still waiting on a few parts to get the motor running (7 speed shift kit ftw!) but im enjoying getting fit again
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
The Following User Says Thank You to bobo333 For This Useful Post:
HHOTDI (12-21-2012)
Old 12-21-2012, 12:30 AM   #147 (permalink)
ron
FYI you should seal the tank and add a fuel filter ,my cruiser gave me nothing but trouble until I added a filter and sealed the tank, does about 20mph with the 49cc motor, my friend built his with an 80cc and it is scary fast! with no suspension or good brakes.
Old 12-21-2012, 10:30 AM   #148 (permalink)
Rapturee
HHOTDI's Avatar
That's cool, now you're talking... :{)
Old 12-21-2012, 11:17 AM   #149 (permalink)
ron
by the look of your frame /motor set up you might do what I had to do I used a pipe fitted between the seat rail and the bottom rail with the motor mounted to it then bolted that copper pipe to the bike frame with drive/self tapping screws
Old 12-21-2012, 10:07 PM   #150 (permalink)
Thanks guys,
ive ordered a "sick bike parts" shift kit and some other bits and bobs for it so i have to wait for them to arrive before i can bolt it all in but i think i might have to make a new bottom mount because the bottom tube is much wider than the motor is designed for
i think the exhaust will have to be moved slightly but i might add a custom expansion chamber anyway so that isnt really a problem
I put some light on yesterday so i can ride at night, maybe i should start a new thread just for the bike?
12v Milwaukee tool battery holder and battery and switches to turn the lights on and off:
