Project: The AeroFocus
The Plans:
http://i1271.photobucket.com/albums/...FocusFinal.gif Plans: (Mod)(Description)(Status) LRR tires - 195/60R15 Bridgestone Ecopia EP422 - Complete Weight Reduction - most of interior removed - Complete Boat Tail - hatch is still functional - Complete Smooth Wheel Covers - attached with zip ties - Complete Rear Wheel Skirts - coroplast and aluminum rib - Complete Front Wheel Arch Gap Fillers - coroplast and tape - Complete Upper Grille Block - coroplast - Complete Belly Pan Side Skirts Wheel Fairings Rear Wheel Boat Tails Table of Contents Framework 1: http://ecomodder.com/forum/showthrea...tml#post320702 Framework 2: http://ecomodder.com/forum/showthrea...tml#post320845 Framework 3: http://ecomodder.com/forum/showthrea...tml#post320915 Backplate: http://ecomodder.com/forum/showthrea...tml#post321008 Backplate 2: http://ecomodder.com/forum/showthrea...tml#post321076 Framework Complete: http://ecomodder.com/forum/showthrea...tml#post321146 Hatch Open: http://ecomodder.com/forum/showthrea...tml#post321150 Tail light wiring: http://ecomodder.com/forum/showthrea...tml#post321424 Coroplast Skin 1: http://ecomodder.com/forum/showthrea...tml#post321727 Coroplast Skin 2: http://ecomodder.com/forum/showthrea...tml#post321918 Coroplast Skin 3: http://ecomodder.com/forum/showthrea...tml#post322047 Smooth Wheel Covers: http://ecomodder.com/forum/showthrea...tml#post322526 Boat Tail to Body Transition Redo: http://ecomodder.com/forum/showthrea...tml#post324528 Tuft-Test: http://ecomodder.com/forum/showthrea...tml#post325211 Smooth Wheel Covers and Front Wheel Arch Gap Fillers: http://ecomodder.com/forum/showthrea...tml#post325517 |
Construction Begins
First Piece installed:
http://i1271.photobucket.com/albums/.../boattail1.jpg Second Piece installed: http://i1271.photobucket.com/albums/.../boattail2.jpg Top and Side Pieces installed: http://i1271.photobucket.com/albums/.../boattail3.jpg Ignore the angle of the top pieces because those are simply being bent by gravity right now and are not in their final resting place. |
Glad to see another tail coming to life :)
Are you direct bolting to the car? |
Yeah, Holes drilled right through the hatch. I'm not too concerned about rust because the car already has so much of it :thumbup:
The stuff you see on the hatch surrounding the metal is masking tape to protect the paint during drilling. |
I've wanted to see a tail on one of these since that bodystyle first came out .
Hope it all works out for you . |
I hope you can make it to the tail meet :)
4 tails in a row :) |
Go, Man, GO:thumbup:. Looking forward to watching this build!:D
What do you plan on covering it with?
Fun, fun! Subscribed.
