Old 11-09-2009, 09:28 PM   #11 (permalink)
93 Metro Streamliner
AeroMetro - '93 Metro
In CA and AZ, the limit is 75 and everyone goes 80+.
The epoxy will be around $400 to $500 vs. about $200 for polyester. Everything I have read says the epoxy is tougher, more waterproof, more resistant to cracking, and better in a collision. The extra cost there is offset by the foam being MUCH cheaper than urethane.
There is no rollcage, but I have a rear strut brace and 3-point Sparco belt, and I am putting in heavy side door beams for protection and chassis stiffening. The passenger side is also hinged as a luggage compartment and both sides of the top can be removed for a two seat convertible with no windshield.
The canopy is an acrylic aircraft canopy.
Old 11-09-2009, 10:43 PM   #12 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
I'm with the other guys. You have a lot of length behind the rear wheel. Even with an eleven degree taper, you could reduce the wake area by a lot, both in plan and in elevation.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 11-09-2009, 10:45 PM   #13 (permalink)
Big Dave's Avatar
I do like the idea of a designed single seater for a commuter car.
4" Slam
Old 11-09-2009, 10:47 PM   #14 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Me too. I think the VW 1L lays out a pretty decent template for such a thing.
Old 11-09-2009, 11:17 PM   #15 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
There is considerable overlap between good vinylester and cheap epoxy. If you really want tough, consider System Three Phase II (no financial interest here, etc. ) but before you are done sanding, I'm sure you'll consider finishing off with an easier-sanding substance. If you want good properties, seriously consider vacuum-bagging. It would help get the labour down with epoxy. WEST also has GLR resin to save layup labour, and it can be heat-cured in the sun for improved properties. . . .
For a big boost in crash safety, add layers of cloth and goo to your foam blanks, and finish the inside as well. And really taper out the material from the hard points.
I'd definitely make it as small and tapered as possible, as suggested above.
Old 11-09-2009, 11:21 PM   #16 (permalink)
P.S. - Aircraft use vinylester for the flame resistance.
And some Kevlar cloth on the inside is marvellous for crash resistance. Just don't try sanding it, at all.
Old 11-09-2009, 11:56 PM   #17 (permalink)
There is a lot of taper in the top view, but as I already mentioned, this will be used at fast highway speeds, and other cars have had terrible stability problems with too much vertical taper.
I moved the battery to the rear axle, but I can still pick the rear wheels off the ground with my bare hands.
The tail is almost two feet narrower than the rear fenders.
For sanding, I will be coating it with that glass micro-bubble stuff.
Old 11-10-2009, 12:02 AM   #18 (permalink)
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
can you post a picture of what you are currently working with so we have a better idea?
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 11-10-2009, 12:08 AM   #19 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
Originally Posted by hypermiler01 View Post
The wheels are 14x5.5" Mazda RX7 alloys, very light, and I am going to try Nokian H tires.
I know the Mazda bolt pattern of that vintage is one of the few that'll fit the Suzukiclones. I've been keeping an eye out for a set of 13 inch "phone dial" alloys from a 323. No luck yet. (Also don't know what they weigh relative to my stock steelies.)
Nokian H - that the same thing Chang uses on his 118 mpg CRX? Modified Honda CRX HF Scores 118 MPG in Fuel Economy Run | Hypermiling, Fuel Economy, and EcoModding News - EcoModder.com
Originally Posted by RobertSmalls View Post
The Jaray body looks like it comes pretty close to that. MetroMPG, any idea what the Cd of that is?
Sorry, nope.
Old 11-10-2009, 10:24 AM   #20 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I can't come up with a figure, either, but I did find the 1921 Rumpler Teardrop-Car's 0.28 Cd in "World History of the Automobile", which might be a book worth reading.
What a beautiful car. Its rear fenders illustrate how to add illuminated width to your streamlined car without adding much drag.
14x5.5"? You can fit the 12lb LRR Insight tires on there.
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/project-aerometro-thoroughly-underway-now-10927.html
Posted By For Type Date
EcoModder.com Latest Blog Posts This thread Refback 11-11-2009 09:34 PM
Yet Another EV Project - 1975 EVA Metro (Renault 12) Restomod mcmahon.craig Fossil Fuel Free 12 01-07-2012 07:07 AM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 152 10-27-2011 01:28 PM
Mullet's Metro Project Johnny Mullet EcoModding Central 302 02-06-2011 08:04 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
Project 60/60 Xfi Metro and Singh grooves metromizer EcoModding Central 25 09-19-2008 09:25 AM
