Old 05-28-2011, 04:40 AM   #91 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Originally Posted by jedi_sol View Post
Since temps do not fluctuate very much for underground tanks, will temperature flucuations have a significant impact on the gas in my fuel tank, in terms of volume? Or are the changes so miniscule, it's not even a factor?
The expansion factor for gasoline is 0.00106 / °C.
If you heat 1 gallon of gas 20°C, it'll expand to 1.0212 gallon.
(Say 10° underground storage temperature vs. 30°C tank temperature.)
That's a 2% difference.
Will that affect how much gas I can fill up? Would this cause underfill/overfill?
It's not dramatic, but it definitely affects the fill-up in warm weather.
The key factor is not what goes into the tank, but what fuel is still in there.
Filling up with a lot of expanded fuel still in the tank, would show a lower amount of fuel going in, and show artificially better mpg.
Lifetime fuel consumption :
The Following 2 Users Say Thank You to euromodder For This Useful Post:
jedi_sol (05-28-2011), Piwoslaw (05-28-2011)
Old 05-28-2011, 02:39 PM   #92 (permalink)
Aero Sol - '93 Del Sol GSR
90 day: 40.31 mpg (US)
So assuming you still have gas inside your tank, filling up in cooler temps still applies. Maybe not so much as in "getting your moneys worth at the pump," but more in terms of getting accurate fillups when tracking mpg.
Old 06-04-2011, 09:44 PM   #93 (permalink)
MPG updates
Ever since the power steering delete.
Drove 240miles and still above the half tank mark = on track to hit 48mpg!
Old 01-14-2012, 08:46 AM   #94 (permalink)
2007Prius - '07 Prius Base
90 day: 44.4 mpg (US)
1996s10 - '96 S10
90 day: 20.01 mpg (US)
Ah it's like the end of the book is missing! I'm in the middle of pondering my next car Crx,del sol, fiero, ?? I'm REALLY encouraged by reading this thread and you guys have given me a lot to think about.
The foam plug is awesome and I plan on trying that out.
Someone mentioned it looked like you had shrink wrapped a belly pan but you used coroplast...had anyone ever tried heavy duty plastic sheeting for a belly pan?I don't know how you would attach it or if it would just flutter and flex too much? Seems like it would have potential especially if the exhaust was wrapped with heat wrap the whole length.
Jim
Old 01-14-2012, 03:16 PM   #95 (permalink)
Toothless - '94 Del Sol Si VTEC
90 day: 30.16 mpg (US)
Jim
I'd say the CRX is the best @ stock, while the Del Sol could have the lowest Cd after a boat-tail install.
I like coroplast because it's easy to work with and sufficiently stiff, that's why I'd use it over sheet plastic.
Tank|Trip Milestones
[x] [x] 30mpg - 125% EPA
[x] [x] 33mpg - 138% EPA
[ ] [x] 36mpg - 150% EPA
[ ] [x] 39mpg - 163% EPA
[ ] [ ] 42mpg - 175% EPA
[ ] [ ] 45mpg - 188% EPA
[ ] [ ] 48mpg - 200% EPA
Old 01-19-2012, 12:40 AM   #96 (permalink)
yeah I used coroplast. I screwed it on the underside to the side skirts and front and rear bumpers, then secured it down the middle using zip ties. Yes, part of the rear section did get caught in the wind and tore off, in which I had to secure down again. I left enough space around the exhaust so melting was not an issue. however it did melt around the engine and transmission. I am now in the process of redoing the underbelly by building an aluminum frame underneath the car that will allow me to screw it down in more places.
The del sol is a tough starting point because the stock cd is 0.35, which one of the highest for a Honda. I think the crx is a better starting off point. But then again, the del sol will be a newer car with more options for an engine/tranny swap.
EG seat swap Del Sol n2 EG Civic Nden DIY / How-to 6 04-02-2010 02:30 AM
My new car. Honda Del Sol pgfpro Introductions 4 08-29-2009 01:28 AM
1993 Honda Del Sol conversion delsolectric Fossil Fuel Free 5 06-09-2009 12:18 PM
Regearing my Honda (1994 Del Sol VTEC) Shortie771 EcoModding Central 79 06-05-2009 01:04 PM
Project: Del Sol Kammback Trial Mockup jedi_sol Aerodynamics 19 04-14-2009 10:52 AM
