Old 06-06-2008, 01:45 AM   #21 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Destination unknown:
I dun busted a boot:
Anyway, I think everything is off besides the shift linkage and mounts, we'll see about dropping the engine tomorrow morning and getting the new one in!
Old 06-06-2008, 01:51 AM   #22 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
I like how the first picture has the licensed plate blacked out, but the rest don't. So lazy...
How are you going to pull the engine? Do you have a hoist, are your pulling it out from under the car, or are you using a 2x4 and a couple of guys? Have you converted your harness to OBD-1 yet? Lastly, are you going to get your engine certified or is that not necessary in New Jersey?
I'm jealous. I wish I had prospects of 60mpg...
EDIT: I see the story continues.
- LostCause
Old 06-06-2008, 02:04 AM   #23 (permalink)
Dartmouth 2010
SVOboy's Avatar
I didn't think about it until I hit that picture...
I'm going to drop the engine onto the skateboard, jack the car up like mad, and roll the engine out.
I've been obd1 for a while, cuz I wanted to play with chipped ecus.
Not necessary in jerz,
Old 06-06-2008, 02:12 AM   #24 (permalink)
hypermiling newbie
im also in the beginning stages of a HF crx build. my goals are 1400lbs, full interior, stock appearance, and 70mpg, on modded rebuilt engine 1.5L.
good luck
Old 06-06-2008, 02:14 AM   #25 (permalink)
Dartmouth 2010
SVOboy's Avatar
You can do it, just check out coyote's metro build,
Old 06-07-2008, 06:46 PM   #26 (permalink)
Dartmouth 2010
SVOboy's Avatar
Update, got some questions:
http://ecomodder.com/forum/showthrea...2464#post32464
Old 06-08-2008, 09:28 PM   #27 (permalink)
Dartmouth 2010
SVOboy's Avatar
The way I'm planning on doing it introduces a little kink into the fuel line between the filter and rail, is this okay or should I go out and buy a new line?
Old 06-08-2008, 09:44 PM   #28 (permalink)
Dartmouth 2010
SVOboy's Avatar
Can anyone confirm that 18 is the egr control box: http://estore.honda.com/EPC/images/p...SR33B1305E.png ?
Majestic has it for 45, so if so, I wanna order it tonight. Ideas?
Old 06-08-2008, 10:09 PM   #29 (permalink)
Veggiedynamics
Extreme CRX-HF - '87 CRX custom areo
90 day: 50.8 mpg (US)
good luck
how are you going to eliminate 400 lbs?
Old 06-08-2008, 11:06 PM   #30 (permalink)
Dartmouth 2010
SVOboy's Avatar
Current issues (making a list for myself):
-fuel line
-driverside mount
-a/c wiring
-a/c in car
-o2 sensor
More to come...
The extreme AreoCRX-HF project ebacherville Aerodynamics 278 04-17-2010 01:26 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 06:14 PM
1st gen crx hf watson EcoModding Central 13 03-17-2008 01:16 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 03:17 AM
