Old 06-13-2008, 06:13 PM   #51 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
IIRC there is a bleeder screw on top of the thermostat housing on your engine.
Try opening that first.
Yes double check all your wiring first. I love the fact that you hid all the wires,I'm not that brave, so you gotta at least consider that.
Schultz.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 06-13-2008, 06:17 PM   #52 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
The bleeder valve isn't actually on the tstat, but I'll fiddle with it more later.
Old 06-13-2008, 07:25 PM   #53 (permalink)
Dartmouth 2010
SVOboy's Avatar
Could the issue possibly be a bad ground?
Old 06-14-2008, 11:36 AM   #54 (permalink)
Dartmouth 2010
SVOboy's Avatar
Now my next question is this: I'm looking at wiring diagrams, and what I seem to notice is that on the 02, there are 4 wires bundled together in a braided wire casing (I'll be damned if I can remember what the real name is), so that metal wire casing need to be grounded?
Thankee
Old 06-14-2008, 12:35 PM   #55 (permalink)
Yes Sir, that metal case is the E.M. shield for the wiring and it needs to be grounded.(usually through the connector itself)
And grounds are never a bad thing.
I have found in the past when I have a ghost prob. that sometimes just adding a dedicated ground from the Eng to the trans to the frame to the puter to the bat seems to work. Not necessarily in that order.
Not sure exactly why, it just does.
Old trick from a coworker many years ago.
Hope that helps,
S.
Old 06-14-2008, 01:53 PM   #56 (permalink)
Dartmouth 2010
SVOboy's Avatar
CEL 8 down, CEL 48 to go...
Too bad that's the scary one.
I also have a gunked up tb that won't let the throttle close and am still missing the driverside mount,
Old 06-14-2008, 02:48 PM   #57 (permalink)
Dartmouth 2010
SVOboy's Avatar
Well, none of the wires were blatantly wrong and rewiring the grounds and power to the ecu didn't help, still have a code 48,
Old 06-14-2008, 11:24 PM   #58 (permalink)
Red
Red's Avatar
Send a message via MSN to Red Send a message via Yahoo to Red
Whats the voltage of the LAF?
Old 06-14-2008, 11:44 PM   #59 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
I would stay away from ebay L1H2 O2 sensors. I remember people on GS having issues with them.
I'd complain to the importer who sold you the engine (just to complain ) and check out a junkyard for a used sensor. Hopefully you won't have to splurge the ~$300 Majestic asks.
In the end, you still come out ahead. You have a CVX now and the mileage it gets will be priceless.
- LostCause
Old 06-15-2008, 02:13 AM   #60 (permalink)
Dartmouth 2010
SVOboy's Avatar
No junkyard love around here, but I might be able to check around...
I'll prolly call and whine after I do all the voltage tests in the manual, . Hell, they might have a spare kicking around, seeing as how they're an importer. I checked the warranty and it doesn't cover sensors though.
The extreme AreoCRX-HF project ebacherville Aerodynamics 278 04-17-2010 01:26 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 06:14 PM
1st gen crx hf watson EcoModding Central 13 03-17-2008 01:16 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 03:17 AM
