Old 06-15-2008, 02:51 AM   #61 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
the coolant bleeder valve should be on the front of the motor, where 1 rad hose connects. if ur jdm doesn't have it like mine did.. just swap it from another D block and use some hondbond. worked for me.
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Old 06-15-2008, 04:27 PM   #62 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Verified using the Helms procedure: dead LAF sensor.
Anyone got a spare they wanna sell me?
Old 06-15-2008, 06:24 PM   #63 (permalink)
Dartmouth 2010
SVOboy's Avatar
Budget coming soon...I'm scared.
Old 06-15-2008, 06:57 PM   #64 (permalink)
ttoyoda's Avatar
A "mere" 96 bucks.. what's not to love?
Did coolant or oil dribble on the outside? Are there little holes on the side of the outside part where the wire comes out? Did stuff get in those holes?
Old 06-15-2008, 07:02 PM   #65 (permalink)
ttoyoda's Avatar
From here:
http://www.civicvx.com/lean_burn_info.html
"LAF Sensor Contamination: LAF sensors do not wear out, they typically fail due to contamination. The material that the sensing tip is made of is porous and many types of material will clog the pores or the LAF sensor. As the sensor becomes contaminated it slowly gets slower and slower in its response to changes in the oxygen content of the exhaust. Eventually the sensor may totally fail."
Old 06-15-2008, 07:03 PM   #66 (permalink)
ttoyoda's Avatar
More info from above site:
"There are external air vents on the LAF that must be clear of debris and free of any contaminants to function properly. These vents are built into the body of the LAF sensor. If these vents get clogged, the sensor will not operate properly.
Personal Note - (It may be possible to clean a failing LAF by placing it in a vice (just to hold not to crush) with the sensor facing out and heating the tip with a propane torch. Be careful to not over heat the tip. Keep the tip under 800 degrees to be safe. DISCLAIMER! This is what I've seen/read/heard from other sources)"
Old 06-15-2008, 08:16 PM   #67 (permalink)
Dartmouth 2010
SVOboy's Avatar
I'm currently talking to tom, the writer of that site you just referenced, to get his ideas,
Old 06-15-2008, 09:33 PM   #68 (permalink)
Dartmouth 2010
SVOboy's Avatar
Here's the part that no one wants to hear about:
Costs:
- Swap: $480 (engine and sensors)
- ECU: $40 (came with swap)
- Misc junk: $75 (wire, oil, coolant, et cetera)
- ECU plugs: $15
- EGR control box: $50
- DMM: $22
- Shrink wrap: $5
- Intake cleaner: $4
- Brass fittings: $9
- Fuel line: $79
- LAF: $177
Subtotal: $956
Uncosts:
- Injectors: $55
Subtotal: $55
Total swap cost: $901
Now, keep in mind I still need to buy an o2...but there's also some junk I can sell...Damn expensive crap.
Old 06-15-2008, 11:15 PM   #69 (permalink)
ttoyoda's Avatar
Well I am happy to hear about it
But you did this for the fun of it, right?
IF the propane torch does not work, and you can find someone who has an oxygen-acetylene torch, try heating (gently!, the flame temp is much, much higher than propane) with a flame that has a lot of extra oxygen in the mix. That should help oxidize away most anything with carbon in it.
If all else fails bringing that LAF to life, you could try AS A LAST RESORT cleaning with that (nearly) universal solvent, methylene chloride.
http://en.wikipedia.org/wiki/Dichloromethane
If you have access to a school lab they might have it.
It used to be sold as carburetor cleaner and boy did it work well
Happy days, happy days.
Don't touch, breath, etc. it. Handle everything with tongs.
Make a hole in the lid of a glass jar, run the LAF wires out the hole.. this solvent may dissolve the insulation on the wires after a while, so don't dip too deep. So doing this is a bit tricky. AND I am just guessing that it might work. Never tried it. Still, if it works, worth 95 bucks.
Then there is:
http://en.wikipedia.org/wiki/Carbon_tetrachloride
But you must balance $95 against probability-of-health-problems, etc. and I have the impression you have a lot of natural life years left, so more reason to be concerned with exposures now that MIGHT lead to cancer 40 years from now..
I hope you are wearing gloves when you do all this car work, because mineral oils will pass thru human skin and attack the (liver/kidneys? I forget. Maybe memory brain cells? ) after many years.
Old 06-15-2008, 11:37 PM   #70 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
You should do what I'm planning to do. Now that you have a "spare" engine, find a car with a blown one for cheap and swap in your good spare. Then sell it for a profit to offset the cost of the swap. Given you have the time to pull it off.
The extreme AreoCRX-HF project ebacherville Aerodynamics 278 04-17-2010 01:26 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 06:14 PM
1st gen crx hf watson EcoModding Central 13 03-17-2008 01:16 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 03:17 AM
