Old 06-15-2008, 11:57 PM   #71 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Originally Posted by reformed View Post
You should do what I'm planning to do. Now that you have a "spare" engine, find a car with a blown one for cheap and swap in your good spare. Then sell it for a profit to offset the cost of the swap. Given you have the time to pull it off.
That's a good idea...will keep my ear to the ground.
Old 06-16-2008, 01:39 AM   #72 (permalink)
Dartmouth 2010
SVOboy's Avatar
Just bought the o2, sadly I missent the address on paypal...be careful of that! Hopefully it can get straightened out before it's shipped.
Old 06-16-2008, 01:24 PM   #73 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
Last 3: 57.98 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by SVOboy View Post
Here's the part that no one wants to hear about:
Costs:
- Swap: $480 (engine and sensors)
- ECU: $40 (came with swap)
- Misc junk: $75 (wire, oil, coolant, et cetera)
- ECU plugs: $15
- EGR control box: $50
- DMM: $22
- Shrink wrap: $5
- Intake cleaner: $4
- Brass fittings: $9
- Fuel line: $79
- LAF: $177
Subtotal: $956
Uncosts:
- Injectors: $55
Subtotal: $55
Total swap cost: $901
Now, keep in mind I still need to buy an o2...but there's also some junk I can sell...Damn expensive crap.
That's not a bad cost for a motor swap at all.
In fact I think you should be proud that it was so cheap.
Old 06-16-2008, 01:42 PM   #74 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 55.06 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
I'mL8I'mL8 - '99 Jetta GLS
90 day: 28.74 mpg (US)
Send a message via AIM to metroschultz
what did I come here for?
Originally Posted by ttoyoda View Post
I hope you are wearing gloves when you do all this car work, because mineral oils will pass thru human skin and attack the (liver/kidneys? I forget. Maybe memory brain cells? ) after many years.
Well now that explains a lot, hey did you see where I left my glasses?
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 06-16-2008, 01:59 PM   #75 (permalink)
02 Golf TDI Driver
I Second this Message!
I used to always be covered in engine grime; always felt lousy, and was sick a lot. When I didn't have to wrench I'd feel better; now I know to keep myself clean and I'll feel better.
It is just all just part of admitting that all of the stuff in a car is dangerous. I have 2 friends who regularly wash their hands in Gasoline/ kerosene; 2 of them have already had cancer. Do the Math.
Old 06-17-2008, 09:21 PM   #76 (permalink)
Dartmouth 2010
SVOboy's Avatar
Currentness: Haven't felt much like working on it, and seeing as how I don't need to drive anywhere, I haven't been,
More updates when the o2 shows up, but until then, I'm going to figure out how to remove the inside a/c stuff and try to sell that...
Anyone wanna buy a crx a/c system?
Old 06-18-2008, 05:47 AM   #77 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
u don't want ac ? omg i'd whine w/o it in hot so-cal lol. best of luck! keep us updated. i'm taking another trip to the yards wed a.m. with a buddy.
what u don't know, CAN hurt you because if you don't know your rights, its like you don't have any at all. ID Theft Services & Resolution available... check out
http://www.prepaidlegal.com/hub/deantaber
Old 06-18-2008, 06:00 AM   #78 (permalink)
British Ecomod Hypermiler
AXMonster's Avatar
Foci - '03 Ford Focus Tdci Ghia Estate
90 day: 64.37 mpg (US)
The AXe - '97 Citroen AX 1.1i 5 Door
90 day: 46.78 mpg (US)
O2 sensors can be brought back to life by sitting the tip in lemon juice.
I know it seems wired, but it works! How long it works for I don't know, but heating with a gas torch, then sticking in lemon juice overnight would probably be a good method.
I cleaned a regular O2 sensor on my Supra and although it looked clean on the outside casing, the amount of crud that came out in the lemon juice was amazing.
1997 Citroen AX 1.1i SPI
2003 Ford Focus 1.8 Tdci estate
Ecomods: See my garage
Old 06-18-2008, 08:37 PM   #79 (permalink)
hypermiling newbie
im lucky enough to have an '88 HF CRX w/o AC... so i wont be adding the 20+lbs to mine thanks... just wait till you pick up the bracket alone for the ac pump...
Old 06-19-2008, 02:00 AM   #80 (permalink)
Dartmouth 2010
SVOboy's Avatar
Well, luckily I get to remove it,
The extreme AreoCRX-HF project ebacherville EcoModding Central 276 01-01-2009 12:56 AM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 06:14 PM
1st gen crx hf watson EcoModding Central 13 03-17-2008 01:16 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 03:17 AM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
