Old 06-19-2008, 05:43 PM   #81 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
It works! I'm giving the preliminary thumbs up to these guys: http://cgi.ebay.com/ebaymotors/ws/eB...037366169&rd=1
Old 06-19-2008, 06:05 PM   #82 (permalink)
CRX HF Vtec-e
CRvX HF - '90 CRX HF
Good to hear since that's the same one i ordered for mine.
Old 06-21-2008, 11:09 PM   #83 (permalink)
Dartmouth 2010
SVOboy's Avatar
New question: http://ecomodder.com/forum/showthrea...7126#post37126
More in the upcoming.
Old 06-24-2008, 09:16 PM   #84 (permalink)
Dartmouth 2010
SVOboy's Avatar
Evidently I hadn't tightened down some damn nut for that forgotten-named rod that goes between the lca and the front cross member.
Old 06-26-2008, 09:59 PM   #85 (permalink)
Dartmouth 2010
SVOboy's Avatar
^^ So now that I've tightened it there is a loud clunking with every revolution of the wheel.
Old 06-26-2008, 10:16 PM   #86 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 j30
90 day: 22.74 mpg (US)
got a pic of the nut/rod?
Old 06-26-2008, 10:43 PM   #87 (permalink)
Dartmouth 2010
SVOboy's Avatar
I'll look around for a blowup, but I'll prolly just take the front end off the car tomorrow and mess around/retighten it.
Old 06-27-2008, 04:32 AM   #88 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
Originally Posted by SVOboy View Post
i bought one for a hundred clams less... $60 approx. with buttconnetors
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Old 06-28-2008, 07:37 PM   #89 (permalink)
Dartmouth 2010
SVOboy's Avatar
According to the helms manual I may very well have a short in my VSS wiring.
Also, I believe the shift up light is found on D1, will test that hypothesis later.
Old 06-29-2008, 03:26 PM   #90 (permalink)
reformed's Avatar
Money pit - '97 j30
Forgot about ya saturday. If you still need me to look up the pin output, I'll be at a friends shop on tues and back to my regular job on wed so either way I can get it.
Have you tested the VSS wire with a testlight or meter yet? When I test it, I always just tap a wire into it and then run it to my testlight inside the vehicle, then I drive it and see if it starts flashing the light. The faster you go the faster it will flash. If its shorted, it will be a dirty signal (not clean flashes) or just solid ground. VSS sensors usually don't work in reverse either so test it in a forward gear.
The extreme AreoCRX-HF project ebacherville Aerodynamics 278 04-17-2010 12:26 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
1st gen crx hf watson EcoModding Central 13 03-17-2008 12:16 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 02:17 AM
