Old 08-03-2011, 05:50 PM   #1 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
New tires - size up!
I went into to RADIAL TIRES of SACRAMENTO this morning after researching sizes this past weekend.
Background:
THe 02 Q45 Sport came from the factory w/245/45/18 (26.5 inch diameter)on 18x7.5 alloy rims.
At 60k miles I went to a 255/45/18 (27.0" diameter)
The base of the Strut tower on the front is the limiting factor to how tall a tire can be without using 30mm spacers( BAD)
We tried a 245/50/18 and there is an 1/8 inch gap!!!
THe diameter is 27.7 inches.
The tire weighs 31lb and the current size weighs 30 lbs.
They ordered them today and will install tomorrow.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-03-2011, 06:41 PM   #2 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
You could cut off the spring platform and fit threaded sleeves so you can fit 2.5" diameter springs
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
Old 08-04-2011, 03:47 PM   #3 (permalink)
mcrews's Avatar
Got the tires on today.
new 245/50/18 27.7" dia. at 55mph 1625rpms
old 255/45/18 27.0 dia at 55 mph 1725rpms
will do mpg runs in a day or so.
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-05-2011, 11:30 PM   #4 (permalink)
mcrews's Avatar
as you can see there is no more room!!!
talk about cutting it close!!!
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-06-2011, 12:09 AM   #5 (permalink)
...beats walking...
...do you think there's "contact" when driving at high speeds and centrifugal forces are attempting to "enlarge" the wheel diameter?
Old 09-06-2011, 10:08 AM   #6 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
If you install coilover suspension you dont need so big spacers to get more room. Or change you ET on your wheels.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 09-15-2011, 02:46 PM   #7 (permalink)
mcrews's Avatar
Well, it's been a month. Had a round trip from Sacramento to LA.....450 miles each way.
No problem with any rubbing.
I had some obdII codes that I had to resolve. And am still addressing some ecu issues pior to my TTT (trip to texas) on Oct 12.
But I just ran a brief highway run.
At 63mph 1775rpms got 30.9mpg (didnot have the grill block or the front underbelly panel in place)
epa is 22mpg highway.
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-15-2011, 06:20 PM   #8 (permalink)
...beats walking...
...cars need an "electronic" wheel diameter compensation "box" to allow for use of different diameter wheels & tires!
Old 09-16-2011, 12:38 AM   #9 (permalink)
mcrews's Avatar
somebody was posting that in europe it's illegal to go up or down in size........
I run a garmin gps on the dash right above the scangauge, so it gives the correct speed.
That way I don't tie up one of the 4 displays on the scangauge.
ECO MODS PERFORMED:
First: ScangaugeII
Old 09-16-2011, 12:40 AM   #10 (permalink)
mcrews's Avatar
Why would I want to ruin the electronic suspenion........
ECO MODS PERFORMED:
First: ScangaugeII
